Advice please about loss of broadband
- Advice please about loss of broadband
- « Previous
- 1
- 2
- Next »
Re: Advice please about loss of broadband
29-05-2012 11:39 AM
Hi Jojo
Thanks for your reply.
When the broadband went off on Friday I did the same as I did when it was off between 14th - 18th May. I turned the router off, diconected it from the extension socket, changed the filter and plugged it in to the test socket. It's been connected and powered up all the time except for last Sunday when I had to go out and the router felt extra hot. I turnedit back on that evening and it's been on ever since.
I would be so grateful for ay help you could give me as I only joined on 30th April and had no connection for 11 of those days. I'm getting really despondant.
Regards Linda
Regards Linda
Message 16 of 23
(600 Views)
29-05-2012 12:09 PM
Hi Linda, does the modem/router still feel extra hot? because this is beginning to possibly sound like a modem/router fault which I expect Jojo can address.
With regard to the posting stats problems do you know about PM's (The "My Messages" in the menu bar at the top)? I'll send you a PM and we'll see if we can sort the posting out there rather than clog the thread, which we'll leave for the fault problem.
Message 17 of 23
(600 Views)
29-05-2012 1:38 PM
Hi Linda,
Are you still in the test socket or have you moved it back to the extension? Below is the connection graph since you joined us. It did seem a lot better in the beginning.
Jojo
Jojo
Message 18 of 23
(600 Views)
29-05-2012 3:36 PM
@Jojo
Was there anything indicating what the fault was in the engineers report from when there was no connection for 5 days?
Message 19 of 23
(600 Views)
29-05-2012 4:57 PM
Hi Jojo and Anotherone
I've just got back online and keeping everything crossed. BT Engineer has been fixing faults at the exchange.
Jojo
I'm still in test socket and will leave it there til tomorrow. When I first joined I attached it via extension socket once set-up was completed as I don't have an electric socket anywhere near to the master socket!
Anotherone
Thanks for pm, I will read it now.
Many Thanks for all your help
Regards, Linda
Jojo
Anotherone
Regards, Linda
Message 20 of 23
(600 Views)
30-05-2012 10:41 AM
I can see the fault's still in hand, unfortunately it doesn't look like the work the engineer did has fixed the issue but our team are on the case and chasing for you. We'll let you know as soon as we have an update,hope it gets sorted soon for you.
Message 21 of 23
(600 Views)
01-06-2012 12:38 AM
Hi
Thanks Matt
I was sent an update Thursday afternoon to say that line now appears stable.
My connection has been absolutely fine for 2 days, so feeling very hopeful that the problems at the exchange are now fully fixed.
I'm really grateful to all at Plusnet who have been so proficient and supportive, and a big thank you also to Anotherone for all his advice.
Thanks Matt
Message 22 of 23
(600 Views)
01-06-2012 9:59 AM
Message 23 of 23
(600 Views)
- « Previous
- 1
- 2
- Next »
