Adsl2+ or GDMT
- Re: Adsl2+ or GDMT
Adsl2+ or GDMT
08-03-2010 10:53 PM
I got adsl2 last week and connected at adsl2+ got a connection of 6250 up 584 tried adsl2 and got 7248 up 826 connected as gdmt and get
Connection Status Connected
Us Rate (Kbps) 992
Ds Rate (Kbps) 7488
US Margin 6
DS Margin 2
Trained Modulation GDMT
Thats at night with gdmt I connect at 8256 in the day
The other thing is my Plusnet profile is stuck at 5500 and I have connected at over 7000 for months.
So why is there such a difference if I connect at adsl2+ a few K ok but a couple of meg? So what do i do stay at gdmt or not I am still in the first 10 days training. If I use adsl2+ it doesnt drop the line but it locks up it show connected but there is no data a ping get through every 6 pings.
I have tried 2 routers both with the same results
Us Rate (Kbps) 992
Ds Rate (Kbps) 7488
US Margin 6
DS Margin 2
Message 1 of 3
(1,152 Views)
2 REPLIES 2
Re: Adsl2+ or GDMT
09-03-2010 7:25 AM
which routers do you have? is it possable to grab telnet graph plot (routerstats, DMT) of the bits tones to compare where adsl2+ is losing the abilty to use certain tones.
are both modulations syncing with the same NM?
wonder if that DS NM on g.dmt made it through the night
Message 2 of 3
(551 Views)
Re: Adsl2+ or GDMT
09-03-2010 2:24 PM
My router is a guru and there is no telnet today I connected as below
Us Rate (Kbps) 960
Ds Rate (Kbps) 8256
US Margin 7
DS Margin 1
LOS Errors 0
DS Line Attenuation 46
US Line Attenuation 27
On GDMT it stayed connected all night no problems compared with adsl2+ were every night it stays connected but you cant get out so you have to reboot the router evn though the line doesnt drop
Us Rate (Kbps) 960
Ds Rate (Kbps) 8256
US Margin 7
DS Margin 1
LOS Errors 0
Message 3 of 3
(551 Views)
