Adsl2+ active or not?
- Adsl2+ active or not?
- « Previous
- 1
- 2
- Next »
Re: Adsl2+ active or not?
24-04-2012 11:29 AM
Good news, nice to see the order go through so quick
Message 16 of 17
(105 Views)
26-04-2012 9:00 PM
Just enquiring bout a few things just to make sure everything is ok.
I know that my new line will be fluctuating and unstable etc, after the upload speed was uncapped I lost a bit on the connection rate but I knew that was the case so that fine but i have lost a bit more on the connection rate again, it's dropped from 17070 to 16870 so only a small amount but just wanted to check with you guys and make sure everything is ok and this is expected.
last night I was having some dns issues with my Xbox and the connection dropped around the same time I think as my iPhone lost connection too, again I know the connection has to stabilise so just want to know if it's a common occurance.
On my netgear dg834gt when powering up the router the Internet light will flash amber as normal then go solid green but then goes off and then few seconds later it will start flashing amber again then go solid green and stays like that after the second go, always takes the second go to connect whereas on adsl it only took 1 attempt
Message 17 of 17
(105 Views)
- « Previous
- 1
- 2
- Next »
