Adsl connected but no internet
demonixz
Just switched to plusnet, live date was yesterday so connected router after receiving email asking me to do so. Router did not immediately connect, but did seem to eventually. However no internet at all, and the dsl connection seems to drop v. regularly.
Router remains stuck with a username of tr069@plusdsl.net
Any help much appreciated.
Oh - I keep getting a message from bt wholesale popping up when connecting via iOS
9 REPLIES 9
Aspiring Legend
Fixes: 195
Re: Adsl connected but no internet
@demonixz Welcome to the forum. Try this: Log in to the router, disconnect the DSL cable, change the TR069 to your username (and input your password), reconnect the cable and press the connect button on the screen. No guarantees, but it may work.
demonixz
Thanks, tried that. Sadly it doesn’t yield any different result - connected, but no internet.
Aspiring Legend
Fixes: 195
OK, sorry, but I did say 'no guarantees'. BTW, are you actually on ADSL or Fibre?
demonixz
It was worth a go, and thanks for the suggestion.
Really truely on dsl - exchange only line with no other option 😅
Aspiring Legend
Fixes: 195
OK. Hopefully one of the Help team will spot this and run some checks.
Gel
Aspiring Champion
Fixes: 27
demonixz
I appreciate the suggestions gel, but I’ve literally swapped out a bt hub for a plusnet router, bt hub worked fine so I’m thinking there’s something needs looking at from the pn end.
Fixes: 367
@demonixz
Totally unrelated to this problem, don’t send back your BT hub. It can be configured to work on your Plusnet service and depending on which model you have will give better performance.
Fixes: 1,550
Thanks for your post @demonixz and welcome to our Community Forums
I'm sorry for the issues with your broadband service. I've tested your line today and the tests are showing a fault on the line, so I've raised this with our suppliers now and we've been given an estimated response time of by 15/06/21 23:59:59 for an engineer to investigate further. We'll update you as soon as we know more.
