Adam, you have several PMs :)
gyre
Having some problems with the target SNR margin not sticking.  Can you help?
jojopillo
Re: Adam, you have several PMs :)
HI gyre,
Adam is not here today and PM's really aren't the best way to get support. Can you describe in more detail your issues and maybe change the title of the thread and I can take a look.
Thanks.
Jojo Smiley
gyre
Hi Jojo, thanks for replying.
Adam was working very hard to get me a stable line in the weeks leading up to Christmas, involving several lift and shift attempts.
My current question number is: 38359603.
The problem I have is that despite being on the DLM trial, my target SNR margin has moved to 12dB.  It should be on 9, or even better, 6.
Thanks!
-- gyre --
jojopillo
HI gyre,
no problem, I'll look into that now for you.
Jojo Smiley
jojopillo
Hi gyre,
The no DLM was applied on the 10th and it can take 72 hours to take full effect. If it's not changed by this time tomorrow I'll get in touch with them for you.
Jojo Smiley
gyre
Thanks Jojo.  Smiley
-- gyre --
jojopillo
Hi gyre,
I've just ran a line check and it's still not right. I'll get onto our suppliers now and see what they say.
Jojo Smiley
gyre
Thanks Jojo! Smiley
-- gyre --
jojopillo
Hi gyre,
I've just had that changed and emailed you about it. The BRAS profile will update in 23 hours.
Jojo Smiley
gyre
Smiley
-- gyre --
gyre
Still sitting on 12dB.  No change.  Sad
jojopillo
Hi gyre,
Thanks for letting me know. I'll do some digging and get back to you.
Jojo Smiley
jojopillo
Hi gyre,
For some reason the MSAN is still showing a 12dB SNR. I'll get on to BT now and ask to get that changed.
Jojo Smiley
gyre
Thanks again Jojo. Smiley
-- gyre --
gyre
Oh, wow.  I've finally got a BT bras profile of 2.5mbit/s.  I can count the number of times that's happened in the last few years on my thumbs.  Smiley
However, with the 9dB target SNR margin, I know that's never going to stick before the plusnet profile gets a chance to match it, so would it be possible to lower the target SNR margin further to 6dB.  That way it's much more likely to keep syncing over 2848kbps each time.
Thanks! Smiley
-- gyre --
