Actual speed much lower than estimated speed
- Actual speed much lower than estimated speed
20-01-2015 8:28 AM
Hello,
my estimated speed is 7mb, but i only get around 2.6 mb. Why am i unable to get closer to the estimate? It's rather frustrating.
Message 1 of 4
(684 Views)
3 REPLIES 3
Re: Actual speed much lower than estimated speed
20-01-2015 9:55 AM
Sorry to hear your speeds are low.
At the moment your speeds are banded between 1mbps and 3mbps most likely due to the drops shown below.
Some of these drops look like you've been turning the router off at night. Is that the case?
I'd recommend going through our troubleshooter here so we can investigate further.
https://faults.plus.net
If you have any further questions let us know.
Message 2 of 4
(428 Views)
20-01-2015 10:40 AM
Yes, i did use to switch it off at night, but recently i have been leaving it on, as supposedly that would help with speeds. However, i still seem to get dropouts, so it's not making any difference. I have even selected a channel for my router so it doesn't choose (automatically) a channel that may interfere with the many other wifi routers in the area (possibly causing dropouts).
I tried the troubleshooter, but at a certain point it threw up an error "something went wrong" page, which wasn't very helpful, not that i believe the troubleshooter will help my issue.
Message 3 of 4
(428 Views)
20-01-2015 10:50 AM
If the dropouts are still happening after you've stopped turning the router off then there may well be a issue with the line.
The troubleshooter has gone through to our faults team so they can investigate further and we should know more within the next 24 to 72 hours.
Message 4 of 4
(428 Views)
