Active Directory Domain not resolving on wired connections
- Active Directory Domain not resolving on wired con...
29-01-2014 12:35 PM
I am having problems resolving my local servers domain controllers domain name from any wired connections to our Plusnet Technicolor TG582n router.
I have a windows server 2012 on my local network serving DHCP, DNS, Active Directory.
I have dissabled DHCP on the router and all client machines are correctly recieving their IPs from the server not the router.
All client machines are configured to use the server as the DNS server not the router.
However when i try to join the domain from any of the client machines that are wired to the router, it fails to resolve the domain name. Doing an NS lookup on the domain name from the client machine shows that they are using the routers DNS to try and resolve this which im not sure why as the network cards on the machines are set up to use the server as the DNS server not the router.
If however i connect wirelessly to the network, then i can join the domain successfully and resolve the domain name.
Does anyone have any ideas why this is or is there a way to turn off the DNS from teh router which is overriding the client machine configurations?
Message 1 of 6
(1,233 Views)
5 REPLIES 5
Re: Active Directory Domain not resolving on wired connections
29-01-2014 12:51 PM
Could you post an
ipconfig /allfrom one of the failing PCs.
Message 2 of 6
(607 Views)
29-01-2014 12:58 PM
C:\Users\Incito>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : INCITO-003
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : INCITO.LOCAL
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : INCITO.LOCAL
Description . . . . . . . . . . . : Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30)
Physical Address. . . . . . . . . : 50-E5-49-19-9F-F8
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::dda2:c11c:361e:c669%3(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.103(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 29 January 2014 12:15:11
Lease Expires . . . . . . . . . . : 06 February 2014 12:15:10
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.83
DHCPv6 IAID . . . . . . . . . . . : 55633225
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-6E-F2-9A-50-E5-49-19-9F-F8
DNS Servers . . . . . . . . . . . : fe80::9e97:26ff:fe0b:a8e1%3
192.168.1.83
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:200f:145f:3f57:fe98(Preferred)
Link-local IPv6 Address . . . . . : fe80::200f:145f:3f57:fe98%5(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 134217728
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.INCITO.LOCAL:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
C:\Users\Incito>nslookup incito.local
Server: dsldevice.lan
Address: fe80::9e97:26ff:fe0b:a8e1
*** dsldevice.lan can't find incito.local: Non-existent domain
C:\Users\Incito>
192.168.1.83
C:\Users\Incito>
Message 3 of 6
(607 Views)
29-01-2014 1:20 PM
That looks like it might be a IPv4/IPv6 issue.
Is your server allocating IPv6 addresses? What happens if you go in to the properties of the Local Area Connection and change the IPv6 Properties to specify the server's IPv6 address as the DNS server?
Alternatively, you could try disabling IPv6 on the Pc to see if that sorts it out.
Message 4 of 6
(607 Views)
29-01-2014 1:22 PM
What's the IPv6 address of the server PC? It looks like the client PC is possibly set to use the router DNS via IPv6 and the server via IPv4?
Message 5 of 6
(607 Views)
29-01-2014 2:32 PM
I disabled IPv6 on the client machines and it now resolves correctly, so it looks like that was the problem.
Thanks for all the help
Message 6 of 6
(607 Views)
