Activation date cheesed off
- Activation date cheesed off
27-01-2016 12:49 PM
I've already been waiting nearly a month now for the Internet go live and have had the patience of a saint. It was confirmed to me that no later that THIS MORNING my internet would finally go live. It hasn't. Any ideas!?
Message 1 of 7
(1,080 Views)
6 REPLIES 6
Re: Activation date cheesed off
27-01-2016 1:16 PM
Message 2 of 7
(671 Views)
27-01-2016 1:18 PM
Microfilter in, phone and router connected through this. I have two sockets, an open reach one and normal one, it's plugged into the normal one. Phone is working as normal as have just used it to make a phone call
Message 3 of 7
(671 Views)
27-01-2016 1:20 PM
Message 4 of 7
(671 Views)
27-01-2016 1:41 PM
It's okay, the problem has now been sorted. For some reason it wouldn't accept it being plugged into the micro filter. Plugged adsl cable into open reach socket and it worked instantly. Thanks for the help though!
Message 5 of 7
(671 Views)
27-01-2016 1:47 PM
Message 6 of 7
(671 Views)
27-01-2016 2:00 PM
Hi, to clarify what Matthew was asking. If you have a faceplate fitted on the Master(Openreach) socket which looks like the one on the right here http://www.kitz.co.uk/adsl/splitters.htm , then the Broadband signal is ONLY available at the DSL connector on the master socket, hence the router MUST be plugged in there for it to work. The faceplate has a filter built-in which means that you don't have to use plug-in filters to connect phones plugged in to that or any extension sockets.
Quote For some reason it wouldn't accept it being plugged into the micro filter.
Message 7 of 7
(671 Views)
