Activate broadband
- Re: Activate broadband
Activate broadband
31-10-2013 3:08 PM
My broadband is due to go live tomorrow, but it appears that the installation has completed early, as I am able to sync (at a very respectable rate!). Unfortunately, I cannot connect to the Internet as my router shows an 'Authentication Failure'. Is this because my account has not been activated yet? If so, is there any way it can be done before tomorrow?
Thanks in advance,
Reece
Thanks in advance,
Reece
Message 1 of 7
(1,033 Views)
6 REPLIES 6
31-10-2013 3:17 PM
Probably need to enter your details into the router, username@plusdsl.net and your password, thats what i had to do when i moved from be to plusnet for fibre
Message 2 of 7
(605 Views)
31-10-2013 3:20 PM
I've done that (and definitely entered them correctly!)... I just don't think I'm actually live on the Plusnet systems yet, like I said, it's not due to go live until tomorrow, was just wondering if it would be possible to get on a little earlier. I'm using mobile broadband at the moment and it's terrible!
Message 3 of 7
(605 Views)
31-10-2013 3:26 PM
Give them a call or maybe a DC person will spot this thread.
Message 4 of 7
(605 Views)
31-10-2013 3:36 PM
Hi Reece,
I've just checked the order which, as you mentioned, has completed.
I've activated your account now, so you should be able to connect your router and get online
Message 5 of 7
(605 Views)
31-10-2013 3:44 PM
Working beautifully - thank you. you guys at Plusnet certainly don't hang about... I requested an addon to my phone line last night and it was active about 5 mins later! Very pleased so far.
Would it now be possible to uncap my upload and enable fastpath or is this something that is best left until after the training period?
Thanks again!
Thanks again!
Message 6 of 7
(605 Views)
31-10-2013 4:31 PM
No problem!
I've placed the necessary order for Interleaving to be switched off (Fastpath) and for your upload speeds to be uncapped. I'd expect the order to complete by the end of the day tomorrow.
Message 7 of 7
(605 Views)
