Access to Internet by DVD player
- Re: Access to Internet by DVD player
- « Previous
- 1
- 2
- Next »
26-11-2014 4:28 PM
here are the results of that
C:\>PING 192.168.1.200
Pinging 192.168.1.200 with 32 bytes of data:
Reply from 192.168.1.108: Destination host unreachable.
Ping statistics for 192.168.1.200:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
C:\>PING 192.168.1.201
Pinging 192.168.1.201 with 32 bytes of data:
Ping statistics for 192.168.1.201:
C:\>PING 192.168.1.202
Pinging 192.168.1.202 with 32 bytes of data:
Ping statistics for 192.168.1.202:
Message 16 of 21
(668 Views)
26-11-2014 4:35 PM
Use those addresses for your hardware devices then.
Message 17 of 21
(668 Views)
26-11-2014 4:50 PM
so I put those new settings into the DVD, which it accepted. However it could not connect!!
Message 18 of 21
(668 Views)
26-11-2014 4:54 PM
Can you PING the DVD from your PC?
Message 19 of 21
(668 Views)
26-11-2014 4:58 PM
there is one thing that is bothering me I cannot find a way of gettig rid of the zeros in the single digit space on TP address abd Gateway. I am assuming that a xero is for the purposes of this of no value
Message 20 of 21
(668 Views)
26-11-2014 5:03 PM
You mean 192.168.001.254 ?
If so should be Ok.
Can you PING?
If so should be Ok.
Can you PING?
Message 21 of 21
(668 Views)
- « Previous
- 1
- 2
- Next »
