Access Control - Technicolor Gateway
rixsteve
I'm trying to configure access control on the technicolor gateway but it says the time "Your Technicolor Gateway is currently not configured to meet the requirements to use this feature." When I try sync the time server via the time server status option it fails? Any help would be appreciated.
Thank you
1 REPLY
Fixes: 6
Re: Access Control - Technicolor Gateway
Try turning off the firewall in plusnet's member center.
That should allow the router to access the time server.
https://portal.plus.net/my.html?action=firewall
Need to disconnect and reconnect the ppp session before it takes affect. Also IIRC, after a reconnect, the router waits 5 minutes before getting the time.
