Able to nslookup but no ping? Ideas?
- Re: Able to nslookup but no ping? Ideas?
02-06-2013 9:26 PM
Hi all,
Just had our Plusnet new line installed- had a fault on the phone line, which is fixed- but am now having BB troubles.
But of a weird one- running a Linksys router + Win7 PC plugged in via Ethernet.
I am able to run a nslookup from the PC, which resolves the IP address- but I am unable to ping anything, including Googles DNS 8.8.8.8? Not seen anything like this before
I can however ping 8.8.8.8 from the router itself.
Router was and has always worked flawlessly with our old TalkTalk line.
Any ideas?
Any ideas?
Message 1 of 5
(1,025 Views)
4 REPLIES 4
02-06-2013 9:37 PM
What do you get if you do
CMD
Ipconfig /all
CMD
Ipconfig /all
Message 2 of 5
(619 Views)
03-06-2013 2:30 PM
Message 3 of 5
(619 Views)
03-06-2013 2:33 PM
You haven't got any DNS set on your computer network settings have you?
Message 4 of 5
(619 Views)
03-06-2013 3:13 PM
Incorrect gateway on your computer would cause these symptoms I believe - follow 30FTTC06's advice and paste here
Message 5 of 5
(619 Views)
