ATA Hardware set-up - Linksys RTP300
- ATA Hardware set-up - Linksys RTP300
22-08-2008 1:02 PM
I am new to Broadband Phone but fairly IT competent, however I am having trouble setting up my Broadband/VOIP phone using a Linksys RTP300 router/ATA device.
The router appears to be working fine, it is connected to my ADSL modem via an ethernet cable plugged into the Internet port and the Internet LED is lit and I have a standard analogue phone (set to Tone, not Pulse dialling) connected to the Phone 1 port.
I have logged into the RPT300 Web Utility, and have accessed the Voice section into which I have entered my settings, however I am not confident these have been entered in the correct places. On the basic screen, there are not sufficient fields for my settings and the Advanced screen there are so many settings that it is hard for me to see what I should be entering where? I have listed the settings provided by my ISP/VoIP below:-
Sip domain or realm - sip2.plus.net
proxy server - nat.plus.net:5082
registrar port - 5060
proxy port - 5082
expire time - 3600
and of course... my SIP ID & SIP password!
Can any point me in the right direction, I have read the ATA Admin guide from the Linksys website but was unable to get much information from this and the user-guide which comes with my device gives no advice regarding the Voice tab.
If anyone can help, I'd be very grateful!
Thanks, Chrissi
Re: ATA Hardware set-up - Linksys RTP300
22-08-2008 1:27 PM
Sip domain or realm - sip.plus.net (I believe sip2 will be phased out over time)
proxy server - sip.plus.net
proxy port - 5060
Then go to the advance options and look for STUN and NAT setting. STUN should be disabled and then look for outbound proxy or nat setting and enter nat.plus.net:5082.
22-08-2008 5:35 PM
It seems to suggest that you need to go to 'switch to advanced view' after logging in
According to the post you should then be able to see the Outbound proxy fields and fill in the details as described by 'itsme'
22-08-2008 7:08 PM
Quote from: neqstep
Thanks, Chrissi
I have never used this device but try these setting they may help both being linksys devices?
Line Enable: yes
sip port :5060
proxy :sip.plus.net Register: Yes
Make Call Without Reg: No Register Expires: 3600
Ans Call Without Reg : No
Display Name: sip id number User ID: sip id number
Password: sip password Use Auth ID: Yes
Auth ID: sip id number
Audio Configuration
Preferred Codec:G7LLu Silence Supp Enable: no
Use Pref Codec Only:No FAX CED Detect Enable:No
DTMF Tx Method: INFO
Line 1 Advance Settings
Proxy and Registration
Outbound Proxy:nat.plus.net:5082
save settings
United Kingdom Regional Settings
Dial tone: 350@-19,440@-22;10(*/0/1+2)
Ring back: 400@-20,450@-20;*(.4/.2/1+2,.4/2/1+2)
Busy tone: 400@-20;10(.375/.375/1)
Reorder tone: 400@-20;10(*/0/1)
SIT 1 tone: 950@-16,1400@-16,1800@-16;20(.330/0/1,.330/0/2,.330/0/3,0/1/0)
MWI dial tone: 350@-19,440@-22;10(.75/.75/1+2)
CWT1 cadence: 30(.1/2)
CWT2 cadence: 30(.25/.25,.25/.25,.25/5)
CWT frequency: 400@-10
Ring 1 cadence: 60(.4/.2,.4/2)
Ring 2 cadence (BT Call Sign): 60(1/2)
Ring 3 cadence (BT Ring Back): 60(.25/.25,.25/.25,.25/1.75)
Ring 4 cadence: 60(.4/ .8 close commer if i do it I get a smiley face
Ring 5 cadence: 60(2/4)
Time Zone: GMT
FXS Port Impedance: 370+620||310nF
Caller ID Method: ETSI FSK With PR(UK)
Daylight Saving Rule: start=3/-1/7/2:0:0;end=10/-1/7/2:0:0;save=1:0:
UK dial plan
this will change problems when dialing number
( *x. | **x. | 0xxx xxx xxx. | 186 xxx xxxx | [1-8]xx | [1-8]xxx | [1-9]xx xxxx | 00 xxxxx x. | 141 0 x. | 1470 0 x. )
puddy
03-09-2008 11:21 AM
As the device is registered, but I have no dialing tone I thought it might be the regional settings, and I have attached a screen-shot of the regional screen along with screen-shots of the other screens incase anyone can point out where I am going wrong?
If anyone has time to review these I'd be really grateful!
Thanks, Chrissi
03-09-2008 12:50 PM
Having a quick google for rtp300 turns up this http://forum.tpad.com/viewtopic.php?p=2141
which seems to be a similar problem ( although on a much earlier firware than you ) which was solved by upgrading the firmware to 3.1.24 ( yours seems to be 3.1.16 ).
A firmware upgrade may be worth a try... ( unless someone else comes up with a better idea )
03-09-2008 1:01 PM
Quote Also check if under the voice tab of the admin page of the router if the "enable IP dialing" is set to "no" for you to have outgoing calls.
Its not that simple is it ?
