ASUS RT-N66u no access to router page
shure
Just trying to logon to my router to change my gateway and I'm coming up with a grey screen with the following message in the middle of the page:
Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from RT-N66U.
To access the settings of RT-N66U, reconnect to the wireless network and use the updated IP address and port number.
I'm on a wired connection.  I rebooted my PC just in case that would make a difference.  I've checked via ipconfig and the router address is correct (192.168.etc.etc).  I can access web pages fine.  I'm probably overlooking something really obvious but I'm a bit stumped.  How do I get back in?
Joshc
Re: ASUS RT-N66u no access to router page
Good evening,
Have you disconnected to re - connect to a different gateway?Huh
If so check out the service status @ http://usertools.plus.net/status/
shure
er, I can't access my router page to do that (it's what I was planning to do in the first place).  I'm loathe to just yank the cable out as the last time I did that my IP profile dropped to less than 1Mbps.
