ASUS RT-AC66U setup and username issues
tree56uk
i'm trying to setup my new router which is the one listed above. It is connected to the BT open reach modem and I'm currently trying to log in with my plus net username and password. I am on a fibre connection using PPPoE.
The help page states just to use "username@plusdsl.net" with no password however this is not working. I've tried to replace "username" with my actual username and also using my password alongside but these combinations to not seem to work. Am I being completely stupid here or is there something I am missing?
I'm very eager to get online! Thanks in advance for your help.
Fixes: 46
Re: ASUS RT-AC66U setup and username issues
You DO need the password. You should use username@plusdsl.net and the password you use to login to the member centre. The help page isn't very clear but the username/password are the same as those for ADSL.
tree56uk
That's sadly still not working however it may be because I'm trying to do this from an iPhone I shall try again later with a laptop.
for clarity that's 'YourPlusnetUsername'@plusdsl.net (e.g. tree56uk@plusdsl.net if your Plusnet username is the same as your forum name - the same username as you'd use to login to the member centre - and the same password too).
Call me 'w23'
tree56uk
Hmmm I think I might have tried that combination too.
It could be 2 things.
1. Using the mobile router setup interface is borked and has some sort of reload loop, as when I put in what i think are the correct details, it goes back to saying select connection type (PPPoE etc)
2. The fibre hasn't been fully provisioned yet, as in they brought the engineer date forward, but not the switching on of the line.
tree56uk
Sorry for the double post, but the oddness just gets odder.
"Your broadband service is nearly ready. A BT engineer will be visiting your home to install Plusnet Fibre today. Please don't set up your router until the engineer has visited as you won't be able to get online until then." In an email just now.
The BT engineer came yesterday morning. The original fibre provision date and engineer appointment was the 4th of October. Getting a tad confused now.
redbull2k14
do you have the bt openreach modem connected?
tree56uk
The BT Openreach modem is indeed connected, DSL light is solid green and it is plugged into the ASUS. They do seem to talk to each other fine. Just talking to the world outside is the issue Cheesy
Probably worth a call to Plusnet (if the wait's currently not too long) to ask if your internet has actually been activated at their end.
Call me 'w23'
tree56uk
I'm back now with my laptop. Setup worked first time and pleased to report getting 74mb dl and 17mb upstream. All is well now. Must have been the iPhone interface messing up.
