ASUS N55U with Plusnet Fibre
- Re: ASUS N55U with Plusnet Fibre
13-07-2014 12:34 PM
I've recently upgraded to fibre broadband and am trying to set up my existing router. Its the N55U which I understand should work. I've tried loading both firmware 3.0.0.4_374 and 3.0.0.5_374 but neither seem to work. When I plug the ethernet cable from the openreach modem the LAN1 light on the modem doesn't even come on.
I tried following the instructions here http://www.geekzone.co.nz/forums.asp?topicid=126933 but no success. Does anyone have any suggestions?
Message 1 of 4
(1,219 Views)
3 REPLIES 3
13-07-2014 3:08 PM
You have configured it for Wan Via LAN, and put your login details into the correct pages I assume.
If so, probably worth messaging grahameys who says he is using it here.
http://community.plus.net/forum/index.php/topic,127934.msg1111874.html#msg1111874
Also worth looking to see what the ADSL log is saying (System Log>ADSL Log
Will be interested to hear how you get on, because I'll be doing the same as soon as I get FTTC enabled.
Message 2 of 4
(626 Views)
13-07-2014 7:34 PM
Yeah, all the details are right as far as I know.
I checked the log and looks to be a line problem, not sure what to do about it though!
Modulation : Multiple Mode
Annex Mode : Annex AIJLM
Line State : down
Lan Tx : 550
Lan Rx : 272
ADSL Tx : 0
ADSL Rx : 0
CRC Down :
CRC Up :
FEC Down :
FEC Up :
HEC Down :
HEC Up :
SNR Up : N/A
SNR Down : N/A
Line Attenuation Up : N/A
Line Attenuation Down : N/A
Data Rate Up : N/A
Data Rate Down : N/A
Line State : down
Lan Tx : 550
Lan Rx : 272
ADSL Tx : 0
ADSL Rx : 0
CRC Down :
CRC Up :
FEC Down :
FEC Up :
HEC Down :
HEC Up :
SNR Up : N/A
SNR Down : N/A
Data Rate Up : N/A
Message 3 of 4
(626 Views)
13-07-2014 7:39 PM
Can you post the latest page of system general log.
Message 4 of 4
(626 Views)
