ASDL2+ migration
Danplusnet
ASDL2+ migration
Hi
I have just migrated over,I think. Would you mind checking the follwoing for me please to ensure all has gone to plan.
1) I have moved over to 21CN
2) I am now on ADSL2+
3) I am still on fastpath with no interleaving
4) my upstream ability is now uncapped ( I am a gamer)
I did a quick speed test this morning and obtained the following.  What does it mean by an assured rate ?
Test1 comprises of Best Effort Test:  -provides background information.
Download Speed
7298 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speed achieved during the test was - 7298 Kbps
For your connection, the acceptable range of speeds is 1000-7150 Kbps.
Additional Information:
Assured Rate IP profile on your line is - 7150 Kbps
Aplogies if the testing is premature I am now away for a few days and those in the house are less broadband savvy than I?
Much appreciated
1 REPLY
Re: ASDL2+ migration
Hi Dan,
1) Yes
2) Yes
3) Yes
4) No, unfortunately not - I'll place the order to uncap your upstream for you now.
Not sure re the assured rate - it sounds like it should be an assurance that you'll not get less than the assured rate but I'm not convinced. I'll ask about and post back.
With regard to the premature testing, well it might speed up once the training period is done but there's no harm in it Cheesy
