ADSL2+ upstream
- Re: ADSL2+ upstream
ADSL2+ upstream
29-11-2009 6:22 PM
thanks defiant
Re: ADSL2+ upstream
29-11-2009 7:04 PM
maybe add abit on there that you understand it MAY cause downstream sync problems (this is why PN started placing all new orders on capped upstream) personally from the trail days i never saw it improve any ones downstream issues when they capped the upstream as away to see if it solved the downstream issue. so i have no idea where PN got the hard eveidnce from that it was a good idea on the sold product to do this
i would add this info just incase they reply asking you to acknowledge it may causes issue before they action it to BTw and so delaying your order
@PN i couldnt see anything about adsl2+ or upstream wise on the help assitant and so why ive posted a genral ticket pool link, maybe wise to added somthing about the capped upstream on the help assitant
Re: ADSL2+ upstream
29-11-2009 9:54 PM
Re: ADSL2+ upstream
29-11-2009 10:13 PM
Re: ADSL2+ upstream
29-11-2009 11:53 PM
adie:quote
Re: ADSL2+ upstream
30-11-2009 12:02 AM
the upstream speed will be 0.6ish I'd say
Re: ADSL2+ upstream
30-11-2009 1:37 AM
Re: ADSL2+ upstream
30-11-2009 8:39 PM
dick:quote
Re: ADSL2+ upstream
01-12-2009 7:26 AM
one thing i've noticed now tho is my ping has increased by about 5ms. whereas before i would get 37ms consistently to bbc.co.uk, i now get around 43ms:
PING bbc.co.uk (212.58.224.138): 56 data bytes
64 bytes from 212.58.224.138: icmp_seq=1 ttl=121 time=42.274 ms
64 bytes from 212.58.224.138: icmp_seq=2 ttl=121 time=42.249 ms
64 bytes from 212.58.224.138: icmp_seq=3 ttl=121 time=43.518 ms
64 bytes from 212.58.224.138: icmp_seq=4 ttl=121 time=43.186 ms
64 bytes from 212.58.224.138: icmp_seq=5 ttl=121 time=42.760 ms
is a slightly increased ping an expected result of having the upload uncapped?
Re: ADSL2+ upstream
01-12-2009 11:30 AM
I think I put interleaving on when I was uncapping the upstream. this is now being swtiched off. the upstream will remain uncapped and the interleaving will be switched back to what it was within the next 24 hours
Re: ADSL2+ upstream
01-12-2009 5:46 PM
dick:quote
Re: ADSL2+ upstream
03-12-2009 10:18 AM
thanks
Re: ADSL2+ upstream
03-12-2009 4:09 PM
The DLM is not showing the same info as the DSL status check sorry but it might take another 24 hours.
Re: ADSL2+ upstream
03-12-2009 11:11 PM
i have plusnet's own thomson router, if you know how i can check let me know mate.
as of right now my pings are still around 8ms higher than before when my upstream was capped.
thanks for your help so far
Re: ADSL2+ upstream
04-12-2009 3:17 AM
i think when i was on fastpath yestrday they said 0.25 ish now interleaving has bein switched on this morning i get 16
i use to get 16-18ms bbc.co.uk now am getting 33ms on interleaved,
am sure when i was showing people how to get the interleaving status out the thomson a few weeks ago it was clear as day with a channel stat. do these thomson's sneak a firmware update in the background or somthing because the stats the xdsl expand command give now are not what they looked like when i first played about with the 585v7
Quote {Administrator}=>xdsl info expand=enabled
Physical Layer Statistics:
Modem state: up
Up time (Days hh:mm:ss): 0 days, 0:06:18
xDSL Standard: ITU-T G.992.3
xDSL Annex: Annex A
Bearers generic info DS US
Payload rate [kbps]: 2976 811
Attenuation [dB]: 48.0 28.0
Margins [dB]: 9.0 6.5
Output power [dBm]: 0.0 12.5
Number of bearers: 1
Bearer 0 DS US
INP [dmt symbols]: 4.06 2.16
Delay [ms]: 8.00 7.96
R: 16 16
