ADSL2+ trial period finished
- ADSL2+ trial period finished
02-03-2012 2:16 PM
These are my current router stats.
Thompson TG585 v7
DSL Connection
Uptime: 2 days, 4:02:57
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,199 / 19,323
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 7.0 / 20.0
SN Margin (Up/Down) [dB]: 6.5 / 6.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): NA / 0
CRC Errors (Up/Down): NA / 3,743
HEC Errors (Up/Down): 0 / 2,658
My Plusnet profile has been set at 16.8Mb
My download speeds according to Speedtest.net
have been fairly consistant at around 10Mb throughout the trial.
I had been hoping for a speed around about my Plusnet profile.
Is that possible with my router stats or is 10Mb as much as I'm likely to get.
Thanks for any help / advice
Chris
Re: ADSL2+ trial period finished
02-03-2012 4:11 PM
I've set your plusnet profile to 17000, let me know what speeds you get after about 15 minutes.
Jojo
02-03-2012 4:38 PM
Still pretty much the same speed.
screenshot of Speednet tests over the last few weeks attached.
The last test today 4:28pm 10.09 Mb
05-03-2012 11:58 AM
I've just checked the line and the sync's at almost 20Mb but the profile seems to be stuck around 5 for some reason. I've requested an SNR reset for you, that should kick in today at some point and let the line retrain which should improve things for you.
Hope that helps, please let us know how it goes, cheers.
05-03-2012 10:51 PM
Router stats are as shown in the attached jpg
Download speed according to Speednet remain at about 10Mb
and my Plusnet profile is 17Mb as set by Joanne 02-03-12
Chris
07-03-2012 1:45 PM
I keep checking the router stats and download speeds but they remain as previously stated, (see previous posts in this thread).
Is there anything that I should do?
There's an option to "restart" on the router gui, would that serve any purpose?
Chris
08-03-2012 10:18 AM
Looks to me like there's some back end funkiness going on. I need to raise this to get it looked at but can't proceed until you run a BT Speed test. So, if you could do that and let me know I can get moving on it for you.
Jojo
08-03-2012 12:54 PM
Thanks for your continued help
Just ran the BT test. Results attached.
I've had to do it on a wireless connection. To do it wired would cause no end of difficulties.
If wired is an absolute must then I will bite the bullet and start moving the furniture around.
Chris
08-03-2012 1:32 PM
08-03-2012 2:45 PM
Revised BT results, wired this time
Chris
08-03-2012 3:09 PM
08-03-2012 3:58 PM
It did wonder early on in the proceedings if wireless might have been the cause of the problem, but because the router was in the same room as the computer with hardly fifteen feet separating them, I dismissed the idea.
Now I feel such a pillock for not having checked it out then
Thanks for all your patience and help.
Chris
08-03-2012 4:49 PM
