ADSL2+, should it be faster than this?
- ADSL2+, should it be faster than this?
Re: ADSL2+, should it be faster than this?
01-08-2012 11:59 AM
01-08-2012 1:53 PM
01-08-2012 2:11 PM
We can of course try setting the SNR margin as ReedRichards says but that cause disconnections, don't mind giving that a go for you.
01-08-2012 2:12 PM
Before on ADSL:
Downstream line: 29dB
Downstream snr: 16dB
Sync: 8128K
Now on ADSL2+:
Downstream line: 32dB
Downstream snr: 3dB
Sync: 17455K
But I managed to tweak snr down to 0.5dB and it was solid stable and got sync rate of 19583K
Perhap you could ask plusnet to raise a fault and let the fault tech guy investigated for u. But U have to plug your router to the test master socket for them to find out what the higher speed your line can get and they might disabled DLM and lower your SNR to 3dB.
01-08-2012 2:16 PM
Quote from: _Adam_Walker_
Quote How long would I expect to wait for it to attempt a higher speed (or does it not work like that)?
Yep, it does work like that, the speeds may increase a little further after a 3 days of connectivity,
I thought the new 88.23% profile should rise every 12 hours ? Not 3 days (that for old 20CN only) if plusnet say plusnet profile will rise after 3 days then what the point of 21CN instant ip profile straight away. Very annoying for plusnet profile to pick it up within 3 days is unfair. I remember Joanne Pilson say the profile should rise every 12 hours after BT 88.23% instant profile before plusnet profile will rise every 12 hours.
01-08-2012 3:08 PM
Quote from: _Adam_Walker_ Being realistic I think 18mb is over-optimistic for your line especially as we've given you an 11mb estimate and I know you've received speeds closer to that in the past too.
Where does that 11mbps estimate come from? Is it based on the downstream attenuation or is it more complicated than that?
Also, should I be concerned that the downstream attenuation jumped from 17dB to 26dB on migration? Oldjim described that as "terrible".
I've leave it all alone for now, but might request an SNR reset at the beginning of next week if the connection has been stable but there's been no speed increase.
Thanks for your help.
01-08-2012 3:09 PM
01-08-2012 3:27 PM
Quote from: Chris Our profile should change within 12 hours, the actual IP profile should be calculated at 88.3% on each resync.
Well mine doesn't work! 13 hours and no sign of plusnet profile change!
01-08-2012 3:35 PM
01-08-2012 3:37 PM
Quote Downstream line: 32dB
Downstream snr: 3dB
Sync: 17455K
Your Plusnet profile is 15400 and that's correct for the sync speed you've quoted/.
01-08-2012 3:39 PM
The new one is here: http://community.plus.net/forum/index.php/topic,106670.0.html
01-08-2012 3:59 PM
So if my line has been stable for 12 or more hours, in theory your profile should have updated and it would be worth me reconnecting to see if I get a higher speed?
01-08-2012 4:01 PM
01-08-2012 4:21 PM
Quote Plusnet need to fix this.
Please see the other thread where I've replied to you, that gives the reason for our side not updating.
04-08-2012 2:21 PM
Quote Download speed achieved during the test was - 9.33 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 14.19 Mbps
However my Plusnet profile still says:
Quote Estimated line speed:
8Mb (Accurate to within +/- 1Mbit) - Checked on 2012-06-15 10:35:55
Current line speed:
10.3 Mb
So it looks like my profile needs resetting to match the BT one. Can someone do this for me please?
Edit: Could I also have my SNR margin set to 6dB as well (it's been 9/10dB over the last 18 hours)? I'd like to see if this modem can hold an even faster connection than this. I assume if it doesn't the target SNR will automatically go back up?
