ADSL2+ question
- Re: ADSL2+ question
ADSL2+ question
04-12-2012 7:10 PM
Pardon my technical ignorance.
I'm due to have a line installed in January to receive an up to 8Mb service. The local exchange is ADSL2+ enabled, is it likely that the line speed will be better than it was several years ago when I last had a BT line connection to the internet?
My second question. When BT gets round to FTTC I assume this means the street cabinets located nearby will be connected to the exchange by fibre. Will my landline be connected to one of these so that only the last 200 yds or so is copper? Might I get a better connection, say up to 16Mb?
Message 1 of 6
(995 Views)
5 REPLIES 5
Re: ADSL2+ question
04-12-2012 7:16 PM
If the exchange is 21CN ADSL2+ enabled you should be put on that which depending upon how far you are from the exchange could give you better than 8MB speeds.
What does the BT wholesale checker say for you?
You should be connected to a nearby cabinet and if that gets FTTC you should get a LOT faster than 16MB.
Message 2 of 6
(517 Views)
Re: ADSL2+ question
04-12-2012 7:52 PM
Thanks for the speed answer. I don;t have a functioning BT line at the moment but the wholesale speed given in my PlusNet quote was 3-8 probably 5.
Will my line automatically be connected to the fastest non fibre option available?
Message 3 of 6
(517 Views)
Re: ADSL2+ question
04-12-2012 7:59 PM
It should be
If it isn't a quick post here will get it fixed
However given the estimate you may be put on ADSL1 on 21CN - only time will tell
Message 4 of 6
(517 Views)
Re: ADSL2+ question
04-12-2012 8:33 PM
ADSL1 is "up to 8Mbps" so based on your opening post that is probably what you are being provisioned on. Based on the estimate you were given that seems an appropriate starting part. The implied distance by road (likely line length) is such that ADSL2/2+ is unlikely to benefit you and could, in fact, give lower speeds and potential line instability.
The picture on this Internode page compares the technologies (blue vs green areas). Though Internode is an Australian ISP the technology is the same.
Once your connection is operational posting router stats here will enable forum members to advise further.
David
Message 5 of 6
(517 Views)
Re: ADSL2+ question
05-12-2012 10:43 AM
Thanks for the replies chaps. I'm by no means as line speed obsessive as long as it's not crawling and falling over I'll probably be happy.
Message 6 of 6
(517 Views)
