ADSL2+ query
adamwalker
Fixes: 221
Re: ADSL2+ query
Hi all,
FYI I've been running some checks for anniesboy, one supplier system confirm that this is a MAX DSL circuit already and line tests done on another seem to think otherwise. Due to this discrepancy I'll need to dig deeper. I'll reply back here when I've deal with this...
 Adam Walker
jelv
Fixes: 10
Re: ADSL2+ query
Given the sync speeds which are absolutely correct for a 1Mb fixed and the high noise margin which means if they were on MaxDSL they would be syncing faster there's only one conclusion I would reach!
(I did wonder why you hadn't suggested MaxDSL - but if the BT systems are telling porkies...)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
adamwalker
Fixes: 221
Re: ADSL2+ query
Hi again,
The bad news is I can't move the line from fixed 1mb to ADSL max. However the good news is that I have been able to place a modify order to move the circuit to ADSL1 (up to 8mb) on 21CN. That should complete on the 15th so we'll just have to see how things go from there.
 Adam Walker
spraxyt
Resting Legend
Fixes: 75
Re: ADSL2+ query
That looks promising. Smiley
David
anniesboy
Re: ADSL2+ query
Very many thanks to all who have contributed.
Absolutely first class response, especially considering my initial query.
I cant say I follow the technicalities.
I will update after the 15th.
adamwalker
Fixes: 221
Re: ADSL2+ query
No problem, to put it more simply it means that there was a discrepancy between 2 different systems which made it look like you already had an up to 8mb connection where as you clearly don't, but on the upside you will next week. Smiley
 Adam Walker
jelv
Fixes: 10
Re: ADSL2+ query
Adam: Was it the discrepancy that meant you couldn't order MaxDSL?
adamwalker
Fixes: 221
Re: ADSL2+ query
Yes, I would have gone down that router otherwise. The 20CN ordering system (ECO) seems to think the line is already Max, ergo I could not upgrade anything via that system which is why I'm moving the line to 21CN.
 Adam Walker
anniesboy
Re: ADSL2+ query
Many thanks Adam,
Its just happened, looks encouraging.
adamwalker
Fixes: 221
Re: ADSL2+ query
Good to hear, I've just closed the ticket on your account re this, thanks for letting us know.
 Adam Walker
anniesboy
Re: ADSL2+ query
Its even better now,after fifteen minutes ,router disconnects.
ThenFantastic speed (well it is out in deepest Oxon) long may it last
spraxyt
Resting Legend
Fixes: 75
Re: ADSL2+ query
Looking good - I'd be interested to see your router stats (as in reply #5). Could you post them please?
David
anniesboy
Re: ADSL2+ query
anniesboy
Re: ADSL2+ query
My speed has "settled" to this.
anniesboy
Re: ADSL2+ query
Sorry wrong stats before.
Oops they were OK
