ADSL2+ problems - slow connection yesterday and today but high sync speed
- ADSL2+ problems - slow connection yesterday and to...
05-03-2012 10:23 AM
Installed a new router a week ago (Billion Bipac 7800n) to cure an unstable ADSL2+ connection. Was working fine all week until yesterday at 13:04 when it lost connection then regained it. After which, the internet was incredibly slow even though the sync speed was over 11M. A router reboot seemd to fix it but this morning, the internet is really slow again and sync speed is still 11M+.
I have got a ticket open #52327238
I see some other users are also getting slow internet problems but the Plusnet status says all is OK.
Message 1 of 9
(2,014 Views)
8 REPLIES 8
Re: ADSL2+ problems - slow connection yesterday and today but high sync speed
05-03-2012 5:25 PM
Hi cjags,
I can see one of our agents has responded to your ticket and has arranged for the line profile to be reset, which should restore your previous speeds - please let us know if that's not happened?
Message 2 of 9
(856 Views)
05-03-2012 7:11 PM
Yes. I have seen that and have reset the router here.
Speeds are fine again at the moment..
Will monitor over the next couple of weeks.
Message 3 of 9
(856 Views)
08-03-2012 5:11 PM
Connection died today
Have updated the ticket.
Message 4 of 9
(856 Views)
08-03-2012 5:19 PM
Sorry if it's a silly question but have you switched the router off and on? Also, does the router interface have a connect/disconnect button? If so can you try that too.
Message 5 of 9
(856 Views)
08-03-2012 5:47 PM
I am not near the router at the moment so can't do that and because the internet is down, I can't get remote access in to query/reboot the router or connection Give me an hour and I will be able to have a look at things and press some buttons.
Message 6 of 9
(856 Views)
08-03-2012 6:17 PM
Have you been playing with the SNR settings on the router by any chance? (the ability to do this seems to be the reason most people go for this router!)
Might be worth changing it back to the default (-1) if so
Message 7 of 9
(856 Views)
08-03-2012 7:12 PM
@defunked No. Plusnet reset the line last week and the router is in the training period.
@Joanne
Am now at the router and can see the problem. Router stats are:
DMT Status No Defect
Operational Mode ADSL2+
Upstream 447
Downstream 13283
SNR Margin(Upstream) 16.2
SNR Margin(Downstream) 0.3
Line Attenuation(Upstream) 21.5
Line Attenuation(Downstream) 37.0
When the router was last working, the downstream sync was around 9M, not 13M.
Interestingly, the router says it just can't connect to Plusnet.
Port Protocol VPI/VCI Operation Connection IP Address Netmask Gateway Primary DNS
ADSL PPPoA 0/38 Connecting
Log:-
Mar 08 19:11:38 daemon pppd[599]: Using interface ppp0_0_38_1
Mar 08 19:11:38 daemon pppd[599]: Connect: ppp_0_0_38_1 <-->
Mar 08 19:11:47 daemon pppd[599]: LCP: timeout sending Config-Requests
Mar 08 19:11:47 daemon pppd[599]: Connection terminated.
Mar 08 19:11:50 daemon pppd[599]: PPP: Start to connect ...
Mar 08 19:11:52 daemon pppd[599]: Using interface ppp0_0_38_1
Mar 08 19:11:52 daemon pppd[599]: Connect: ppp_0_0_38_1 <-->
Mar 08 19:12:01 daemon pppd[599]: LCP: timeout sending Config-Requests
Mar 08 19:12:01 daemon pppd[599]: Connection terminated.
@Joanne
Upstream 447
Downstream 13283
Log:-
Message 8 of 9
(856 Views)
08-03-2012 7:34 PM
Have restarted the router. Line stats are now:-
Upstream 446
Downstream 10486
SNR Margin(Upstream) 14.0
SNR Margin(Downstream) 3.1
And I have a connection to Plusnet and the internet.
Upstream 446
Downstream 10486
Message 9 of 9
(856 Views)
