ADSL2 or ADSL2+
- ADSL2 or ADSL2+
- « Previous
- Next »
Re: ADSL2 or ADSL2+
02-01-2013 1:57 AM
Back in reply #37 I did say that I had a call from a BT engineer on 21st December to say that the Dis fault was most likely a false-positive and that he couldn't find any other issues so I took the broadband route as the phone route didn't seem to solve anything and I also felt that was the direction Matt was pointing me in his reply #40.
Either way the engineer that came Sunday was a telephone one and not a broadband one - his words. He said he did some work at the exchange but when I pressed him about it he wasn't forthcoming with any further info.
If you're suggesting that this should be put back to a telephone fault then I'll give it a go. Hopefully someone from the Team will pop his/her head in tomorrow and offer some further info or advice before I do anything.
Forum Moderator and Customer
Re: ADSL2 or ADSL2+
15-01-2013 12:40 PM
But here's something strange (to me at least); Around 4am I couldn't sleep so was reading on line when I noticed the line drop. I knew it had as the usual occurrance of Yahoo logging out and back in again automatically.
I then checked the router stats which tells me that the Internet connection dropped at that time but, oddly, the ADSL didn't.
Stats as of a few minutes ago.
Quote Internet connection configuration
Connection information
Connection time 0 days, 9:07:19
Data transmitted/received (MB) 12114.13 / 328089.30
Broadband xxxxxxxxxxx@plusdsl.net
Password ********
TCP/IP settings
Broadband network IP address 212.159.xxx.xxx
Default gateway 195.166.xxx.xxx
Primary DNS 212.159.6.10
Secondary DNS 212.159.6.9
Quote ADSL line status
Line state Connected
Connection time 13 days, 18:08:02
Downstream 5,906 Kbps
Upstream 1,020 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.3
Latency type Interleaved
Noise margin (Down/Up) 3.1 dB / 5.8 dB
Line attenuation (Down/Up) 44.0 dB / 25.0 dB
Output power (Down/Up) 0.0 dBm / 12.9 dBm
Could anyone comment on this - a quirk of the Homehub? Or is this normal?
Re: ADSL2 or ADSL2+
15-01-2013 12:48 PM
One reason could be that Plusnet may have updated their version of the IP profile or just that they moved you to a different gateway to solve connection problems (unlikely as they haven't announced that they were doing it) or something in the Plusnet edge routers lost and regained the session
Re: ADSL2 or ADSL2+
15-01-2013 12:58 PM
If it continues to remain stable then that'll be OK. I was just concerned that it may start dropping frequently again. Fingers crossed.
Re: ADSL2 or ADSL2+
15-01-2013 1:01 PM
Internet up time 11 hours 13 minutes
Broadband up time 5 days 3 minutes
From router log
Tue, 2013-01-15 01:45:14 - Initialize LCP.
Tue, 2013-01-15 01:45:14 - LCP is allowed to come up.
Tue, 2013-01-15 01:45:15 - CHAP authentication success
Re: ADSL2 or ADSL2+
15-01-2013 4:38 PM
- « Previous
- Next »
