ADSL2 or 2+ ?
- ADSL2 or 2+ ?
ADSL2 or 2+ ?
14-11-2011 10:00 PM
I think my Netgear DG834Gv3 might be dying. I have a Netgear DG834Gv4 ADSL2+ router I can use, but lots of websites often don't load properly (eg Hotmail), or hang for several minutes before loading (including Plusnet broadband checker pages).
I see it is set to auto mode, but switching it to ADSL2 instead seems to have improved things. This might be my imagination of course as it's all pretty inconsistent. Is there any logical reason to suspect it will make a difference?
David
David
Message 1 of 9
(1,679 Views)
8 REPLIES 8
Re: ADSL2 or 2+ ?
14-11-2011 10:57 PM
Quote Is there any logical reason to suspect it will make a difference?
Depends what your downstream attenuation is, ADSL2+ doesn't work too well on longer lines so forcing the router to connect in ADSL2 mode can be beneficial.
Message 2 of 9
(647 Views)
Re: ADSL2 or 2+ ?
15-11-2011 7:23 PM
My downstream attenuation is 30.5db. My noise margin is 3db in the test socket with a filter and one wired phone connected at the filter.
Message 3 of 9
(647 Views)
Re: ADSL2 or 2+ ?
15-11-2011 8:06 PM
Did forcing an ADSL2 connection result in significantly reduced sync speed, the main downside I'd expect from that with your attenuation?
What browser are you using?
Problems with some websites not loading correctly can be caused by mismatched MTU settings on the router and PC. Alternatively, have you by any chance got Trusteer installed and set it to monitor connections to problem sites?
David
Message 4 of 9
(646 Views)
Re: ADSL2 or 2+ ?
15-11-2011 9:15 PM
The options available for DSL Mode on the v3 are Auto (Multi-mode), ADSL (G.DMT), and ADSL2+. It doesn't give a choice between ADSL2 and ADSL2+.
Message 5 of 9
(646 Views)
Re: ADSL2 or 2+ ?
15-11-2011 9:37 PM
Quote from: spraxyt Did forcing an ADSL2 connection result in significantly reduced sync speed, the main downside I'd expect from that with your attenuation?
Yes, the speed did drop. However I can see this evening that doing so has not really helped as I couldn't access many sites, not even this one (at the time, router says it is connected and all lights are up, but I couldn't open this site until I'd rebooted it.
Firefox, IE and Chrome all have same problems.
MTU = 1458 on router and PC.
Not using Trusteer
Message 6 of 9
(646 Views)
Re: ADSL2 or 2+ ?
15-11-2011 9:39 PM
Quote from: ejs The options available for DSL Mode on the v3 are Auto (Multi-mode), ADSL (G.DMT), and ADSL2+. It doesn't give a choice between ADSL2 and ADSL2+.
No, this issue refers to the v4 as the v3 is very flakey.
Message 7 of 9
(646 Views)
Re: ADSL2 or 2+ ?
15-11-2011 11:00 PM
If you set MTU on router and PC to 1400 does it make any difference. What operating system is on your PC?
David
Message 8 of 9
(646 Views)
Re: ADSL2 or 2+ ?
16-11-2011 8:44 PM
Thanks for your interest. Can we put this on hold? I have a new Netgear DGN1000 to try and will report back when I have new information.
Message 9 of 9
(646 Views)
