ADSL2+ not much of a speed increase so far.
- ADSL2+ not much of a speed increase so far.
13-09-2010 9:04 PM
Bandwidth (Up/Down) [kbps/kbps]: 446 / 8,389 . This is faster than I ever got before, but not by much. Plusnet shows my current line speed as 6500 (BT checker will not work for me, some kind of java problem) I used to get 6000 or 6500 on ADSL2. I expected more or am I being impatient? Also could anyone inform me how to find my noise margin on the Thompson router, provided by plusnet.
Alan
Re: ADSL2+ not much of a speed increase so far.
13-09-2010 9:22 PM
Quote from: alben I used to get 6000 or 6500 on ADSL2
You mean ADSLmax presumably?
In that band ADSL2+ speeds would typically almost double. Chances are you have a problem with your OWN extension wiring.
Without detailed stats though no-one could say, not just the noise margin but attenuation power etc.
13-09-2010 10:06 PM
Quote from: alben Also could anyone inform me how to find my noise margin on the Thompson router, provided by plusnet.
You could try here - if your router is one of those listed.
Tony
13-09-2010 11:14 PM
14-09-2010 8:53 AM
Quote from: HPsauce Without detailed stats though no-one could say,
14-09-2010 9:04 AM
Downstream Link Info
Loop Loss SNR Margin Errored Seconds Hec Errors Cell Count Speed
41 3.4 0 N/A 27281 8388
Current Line Rate
6500
So, really, that's not far from the mark for your line length.
Jojo
14-09-2010 9:26 AM
Your figures look similar - using 192.168.1.254 follow Broadband Connection/DSL Connection/View More/Details and you'll get all your stats
14-09-2010 10:05 AM
A somewhat (not much) shorter line and you'd possibly see a big increase but you're just a bit too far from the exchange to gain very much from ADSL2+.
16-09-2010 12:02 PM
I'm currently concerned that a year ago I was getting my Plusnet BB via 20CN & Tiscali LLU equipment and I achieved approx 5600kbps download and 668kbps upload speed after some trial profile adjustments by a very kind fellow in Plusnet's support side. When some months back my BB was rerouted via BT gear at my exchange the line speeds went down to approx 4800kbps / 448kbps. When I queried this I was told that BT used a more conservative line speed auto-negotiation on their equipment. Since upgrading to 21CN & ADSL2+ last week my current modem (Thompson TG575 v7) is today showing:-
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 4,283
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 23.5 / 39.5
SN Margin (Up/Down) [dB]: 25.0 / 9.5
I know my Line attentuation implies that I probably won't get a lot better I'm still puzzled as to how my line is now seemingly not able to support anywhere near what I got via the Tiscali LLU equipment.
Alan (not to be confused with the BT one)
16-09-2010 12:17 PM
Quote from: shorty
Why?
It should be capable of double that - around 9mbps.
(You're only on ADSL2 by the way, not ADSL2+)
16-09-2010 1:55 PM
I'm with HPsauce on this one I think you should definitely be getting better performance. It looks a bit intermittent, see logs below. I would refer you to our troubleshooting guide in the first instance and then raise a fault if none of that helps.
[quote=connection logs last 7 days]
Session Started Session Ended Session Duration
10:46 16/Sep/2010 N/A 3:6:7 (on going)
10:13 16/Sep/2010 10:42 16/Sep/2010 0:28:2
05:06 16/Sep/2010 10:11 16/Sep/2010 5:4:32
22:58 14/Sep/2010 00:38 16/Sep/2010 One Day, 1:40:3
03:30 14/Sep/2010 22:57 14/Sep/2010 19:27:15
12:29 13/Sep/2010 03:30 14/Sep/2010 15:0:44
12:04 13/Sep/2010 12:26 13/Sep/2010 0:22:23
10:34 13/Sep/2010 12:03 13/Sep/2010 1:28:16
10:30 13/Sep/2010 10:32 13/Sep/2010 0:1:27
20:42 12/Sep/2010 10:29 13/Sep/2010 13:47:0
20:40 12/Sep/2010 20:42 12/Sep/2010 0:1:50
12:50 11/Sep/2010 20:39 12/Sep/2010 One Day, 7:48:37
16:17 10/Sep/2010 12:49 11/Sep/2010 20:31:36
16:01 10/Sep/2010 16:14 10/Sep/2010 0:13:27
15:52 10/Sep/2010 15:59 10/Sep/2010 0:6:7
15:46 10/Sep/2010 15:50 10/Sep/2010 0:4:19
15:40 10/Sep/2010 15:43 10/Sep/2010 0:3:40
15:40 10/Sep/2010 15:40 10/Sep/2010 0:0:2
15:38 10/Sep/2010 15:39 10/Sep/2010 0:1:0
15:22 10/Sep/2010 15:36 10/Sep/2010 0:14:9
15:15 10/Sep/2010 15:21 10/Sep/2010 0:6:2
15:15 10/Sep/2010 15:15 10/Sep/2010 0:0:2
15:14 10/Sep/2010 15:15 10/Sep/2010 0:0:51
14:47 10/Sep/2010 15:11 10/Sep/2010 0:24:29
13:56 10/Sep/2010 14:45 10/Sep/2010 0:48:45
N/A N/A N/A
N/A N/A N/A
12:20 09/Sep/2010 14:42 09/Sep/2010 2:21:50
12:14 09/Sep/2010 12:17 09/Sep/2010 0:2:51
11:27 09/Sep/2010 12:13 09/Sep/2010 0:46:7
10:13 09/Sep/2010 11:24 09/Sep/2010 1:11:22
10:09 09/Sep/2010 10:11 09/Sep/2010 0:2:4
10:05 09/Sep/2010 10:09 09/Sep/2010 0:4:1
10:02 09/Sep/2010 10:03 09/Sep/2010 0:1:3
20:00 08/Sep/2010 10:01 09/Sep/2010 14:0:51
Jojo
16-09-2010 2:44 PM
I I'm still puzzled as to how my line is now seemingly not able to support anywhere near what I got via the Tiscali LLU equipment.
I have the same issue, I came from tiscali llu my speeds have dropped from what I used to get with them.
I have queried but never really got an answer
16-09-2010 3:31 PM
I don't understand quite what the log is intended to show me. My Thompson modem has been permanently powered and sync'd up since 13th Sept until this morning when I temporarily tried my Netgear DG834GT modem with no difference in line speed apparent. BT were supposed to have sorted out an exchange problem on the 13th which according to Plusnet involved a "lift & shift". They had originally tried to upgrade me the previous week and left me initially without any ATM connection on the 10th Sept. Fortunately this was sorted out on the 11th Sept.
My memory might be playing tricks on me (a senior moment I suppose) but I'm convinced that yesterday my Gateway was "pcl-ag05" but I note that today it's "pcl-ag02". I'm fairly sure that I used to be on"pcl-ag01". I also note that my account shows that "My Current Line Speed" is 21000(?).
I'm confused to say the least! but I'll have a look through the Troubleshooting Guide later although nothing BB-wise in my house has changed for the last 2 years apart from the Thompson modem that I received from Plusnet 10 days ago after they suggested when I asked to be upgraded that there could be a compatibilty problem with my Netgear one. To save confusing the situation I'm intending to stay with the Thompson one for now.
Alan
Alan
16-09-2010 3:56 PM
Alan.
Link Information
Uptime: 0 days, 18:30:46 DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,001
Output Power (Up/Down) [dBm]: 12.0 / 20.5
Line Attenuation (Up/Down) [dB]: 22.5 / 41.0
SN Margin (Up/Down) [dB]: 16.5 / 4.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 123 / 8,708,001
CRC Errors (Up/Down): 123 / 62
HEC Errors (Up/Down): 1,382 / 50
16-09-2010 4:20 PM
You may see your router as not losing any connection but the logs I posted means it has re-authenticated and when it does that it can also authenticate on to a different gateway. So for some reason your connection is dropping so we need to try to find out why. When your connection drops like that your speed will drop too as the system tries to stabilise your line. Once we get to the bottom of the dropping connection we will see the speed increase. Your connection speed just hadn't updated on your account but it now matches your BT profile.
Jojo
