ADSL2 connection; lowered upload speed
Gel
Seasoned Pro
Fixes: 14
Following recent reconnect to Colindale point of presence, d/load speed about the same, but upload has dropped from around 900 to 600 odd- any reasons?
. Product name: Plusnet Hub
2. Serial number: +081441+NQ54605093
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated 01/10/16
4. Board version: Plusnet Hub One
5. DSL uptime: 3 days, 08:17:29
6. Data rate: 679 / 2991
7. Maximum data rate: 695 / 3124
8. Noise margin: 6.6 / 4.6
9. Line attenuation: 36.1 / 61.1
10. Signal attenuation: 36.0 / 56.6
11. Data sent/received: 644.8 MB / 9.0 GB
Fixes: 22
Re: ADSL2 connection; lowered upload speed
Yes, it could be almost any reason, there isn't really anything in the stats to give the reason.
The line quality could have decreased, there could be more noise from somewhere affecting the upstream frequencies. Or the interleaving parameters could have changed but the limited stats from the Hub One do not provide them.
Gel
Seasoned Pro
Fixes: 14
Gel
Seasoned Pro
Fixes: 14
Fixes: 22
I'm pretty sure that Southbank or Colindale will have nothing to do with the speed of your ADSL2+ link between your modem and the exchange.
