ADSL2+ broadband speed variable
- ADSL2+ broadband speed variable
25-08-2014 8:31 PM
Any chance someone can check my broadband settings?
Should have the upload speed uncapped but it seems to be limited lately.
Download speeds are pretty much as usual (8M to 9M) but uploads are down from 0.7M to around 0.4M
Many thanks.
Router stats
Operational Mode ADSL2+
Upstream 660
Downstream 10592
SNR Margin(Upstream) 3.9
SNR Margin(Downstream) 6.2
Line Attenuation(Upstream) 22.2
Line Attenuation(Downstream) 38.0
BT speedtest
Download 8.64
Upload 0.61
Ping 40.00
Many thanks.
Router stats
Upstream 660
Downstream 10592
BT speedtest
Download 8.64
Upload 0.61
Ping 40.00
Message 1 of 4
(720 Views)
3 REPLIES 3
Re: ADSL2+ broadband speed variable
26-08-2014 5:04 PM
Message 2 of 4
(467 Views)
26-08-2014 8:38 PM
Ethernet.
Modem is connected directly to ADSL faceplate.
Message 3 of 4
(467 Views)
28-08-2014 12:12 PM
OK, I can't imagine what else you could try to eliminate this as being a local issue so I'd raise a fault if that continues to be an issue:
http://faults.plus.net
Message 4 of 4
(467 Views)
