ADSL2+ and POTS
ncd
ADSL2+ and POTS
Hi All,
I've got a strange thing happening here now and want to throw it out there in case anyone else has experienced anything similar.
My ADSL2+ service is now working a treat - syncing at a high speed and staying there without issue. That is until I use my DECT phone then it loses sync almost immediately. I've tried to isolate the issue by disconnecting everything but the master socket, a single filter and then the router and the DECT phone and sure enough when that phone rings it drops sync!
Is this plausible at all?
Cheers,
N
1 REPLY
Fixes: 10
Re: ADSL2+ and POTS
If you ring your number with the DECT phone unplugged does the broadband still drop?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
