ADSL2+ and IP block
- Re: ADSL2+ and IP block
ADSL2+ and IP block
27-03-2012 4:09 PM
My exchange (Godstone) is due for upgrade to ADSL2+ by the end of March.
If I was to request a move to this would this have any effect on my current package (old PAYG 15GB) & block of 8 IP's?
Many thanks for any info...
Shamus
27-03-2012 5:14 PM
28-03-2012 7:22 PM
29-03-2012 2:49 PM
http://www.dslchecker.bt.com/adsl/adslchecker.welcome - kind of implies that it is done....
Many thanks,
Shamus
29-03-2012 2:54 PM
If the BT checkers shows availability then that should enable us to place an order on their systems for you.
I shall try that now and let you know how I get on.
Adam
EDIT: order 1-11321530386 now placed and due to complete on 5/4/12
29-03-2012 3:43 PM
Many thanks,
Shamus
P.s how do you know what my Plusnet username is?
29-03-2012 4:14 PM
Quote how do you know what my Plusnet username is?
voodoo err.. no when you register to the community site the form asks you for your Plusnet account username, if you enter that it links one to the other, hence if I search for "shamus" as a community username on our systems it finds your account.
05-04-2012 6:22 PM
many thanks,
Shamus
09-04-2012 9:41 AM
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : ADSL2+(G.992.5) State : SHOWTIME
DS Actual Rate : 14678784 bps US Actual Rate : 444937 bps
DS Attainable Rate : 14756000 bps US Attainable Rate : 1156000 bps
DS Path Mode : Interleave US Path Mode : Interleave
DS Interleave Depth : 64 US Interleave Depth : 1
NE Current Attenuation : 28 dB Cur SNR Margin : 9 dB
DS actual PSD : 20. 2 dB US actual PSD : 12. 1 dB
ADSL Firmware Version : 232201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 12 dB Far SNR Margin : 28 dB
CO ITU Version[0] : 00004946 CO ITU Version[1] : 0000544e
DSLAM CHIPSET VENDOR : < IFTN >
I was previously syncing at >16000000 downstream. This wouldn't be a problem if my upstream had increased significantly.
As can be seen from the above the upstream sync is virtually unchanged as was previously syncing at 444000. Is this a limitation of my line or is some other cap being applied somewhere that is preventing a higher sync rate on upstream?
Shamus
09-04-2012 11:18 AM
10-04-2012 10:25 AM
https://portal.plus.net/my.html?action=data_transfer_speed indicates Current line speed of 6.5 Mb but am syncing at 14678784bps
Could you also check my upload has been uncapped as I cannot sync higher than 444937bps.
Many thanks,
Shamus
10-04-2012 3:44 PM
Your upload order was placed but it is a 5 working day order. It's due to complete on the 17th. As for your speed I've changed your profile to 12900 to allow for your new BT IP profile. This should take effect shortly.
Jojo
10-04-2012 3:50 PM
Shamus
10-04-2012 4:32 PM
would you like me to see if I can cancel the current order, in which case I'll be able to place it manually and get it complete in 24 hours, save you waiting until next week?
Jojo
10-04-2012 4:33 PM
Shamus
