ADSL2+ What does this mean for Plus net customers...
- Re: ADSL2+ What does this mean for Plus net custom...
01-05-2008 1:46 PM
Given that the work has already been started to upgrade the the stuff before the DSLAMS etc, what does this mean for plus.net account holders?
lets say my street... PE6 8QR... gets the upgrade done all the way to the DSLAM, obv i would need a fully ADSL2+ compliant router/modem, but with my existing acocunt with plus.net (up to 8mb) doe sit mean with the right gear i can expect to recieve the full 8mb per sec? or will plus.net begin to release ADSL2+ packages?
Things are looking quite promising with stats like these:
(feet away from exchange/DSLAM)
* 25 Mbit/s at 1,000 feet (~300 m)
* 24 Mbit/s at 2,000 feet (~600 m)
* 23 Mbit/s at 3,000 feet (~900 m)
* 22 Mbit/s at 4,000 feet (~1.2 km)
* 21 Mbit/s at 5,000 feet (~1.5 km or ~.95 miles)
* 19 Mbit/s at 6,000 feet (~1.8 km or ~1.14 miles)
* 16 Mbit/s at 7,000 feet (~2.1 km or ~1.33 miles)
* 1.5 Mbit/s at 15,000 feet (4.5 km or ~2.8 miles)
* 800 kbit/s at 17,000 feet (~5.2 km or ~3.2 miles)
if it does get like that and i get 19-21mbsec... my usage allowance is gonna get raped! hahaha!
Re: ADSL2+ What does this mean for Plus net customers...
01-05-2008 1:50 PM
http://community.plus.net/blog/2008/04/28/plusnets-plans-for-200809/
which includes this bit :
Quote When BT IPStream Max first launched we rushed headlong into upgrading as many customers as we could to ‘up to 8Mbps’ speeds. The resulting service problems caused some big backlogs in our CSC and we ended up with some unhappy customers. So this time we’re going to take things a little slower! In the coming weeks we will announce our plans to trial higher speeds in selected areas of the country. The trials will be opt-in only and we will announce them on our Community site and email customers in the areas where the trial will be available. We’ll need to do a considerable amount of work to build and test our new products.
01-05-2008 1:56 PM
Indeed, ADSL2+ only affects the connection between the DSLAM and your router, so no reason other than marketing not to enable ADSL2+ with an limit of 8Mb until the ISP connects you to WBC.
SW.
3Mb FTTC
01-05-2008 2:10 PM
The easiest way to "guesstimate" your speed is to obtain your DOWNSTREAM line attenuation from your current router and plug it in here: http://www.kitz.co.uk/adsl/max_speed_calc.htm
This will also tell you what speed you "should" be getting on ADSL Max - you may get a surprise!
01-05-2008 2:17 PM
SW.
3Mb FTTC
01-05-2008 2:18 PM
01-05-2008 2:27 PM
Quote from: Jameseh Yeah, we'd definitely have to do some dev work to allow the enhanced speeds, but I'm not sure what work would be required from a Networks perspective.
i would have thought nothing really... from a networking perspective the DSLAMS to the backbone is still at 100gbaseX (100gbit/sec) thats not changing... its just really from the DSLAM through any secondary multiplexers and then into the houses where the change in speed will be.
i guess the only changes will be system account changes, but then it should all run fine regardless of speed changes as the current state of affiars means no two account holders really get the same speeds.
I think PLus.net pro customers will have the best deal... as with traffic prioritisation will really help when the contention ratios get pushed due to a 3x higher speed for the same backbone speeds...
01-05-2008 2:29 PM
Quote from: godsell4 when the exchange is upgraded to WBC/21CN does the connections automagically become ADSL2+ when that happens,
Personally I'd have thought that very unlikely.
The speed is down to the DSLAM you connect to which presumably doesn't have to be changed immediately.
I know the converse applies (sort of) as my local exchange (like many others) doesn't even have a date for 21CN but there's LLU kit in there supplying ADSL2+ connected initially back through BT's network.
01-05-2008 2:48 PM
Quote from: Jameseh Yeah, we'd definitely have to do some dev work to allow the enhanced speeds ...
I am not asking for enhanced speeds, I am happy to have ADSL2+ enabled on the DSLAM and have it limited to 8Mb/s Down and 448kb/s Up ... I just want the better rate adaption on my long line, if the rate adaption really worked, I would have thought PN and BTW would like that as I bet you and they have many man-hours of effort spent on 'speed issue' which are down to the MaxDSL logic. So it is a saving for you and them to spend time on real issues ... wow you could both get better customer satisfaction maybe!
SW.
3Mb FTTC
01-05-2008 2:49 PM
We'll just have to see if the profiling actually is better!
01-05-2008 2:54 PM
05-05-2008 9:47 PM
Quote from: mzivtins
Where did you get your stats from?
16-05-2008 3:54 PM
Down Up
SNR (dB): 19.9 14.0
Attn(dB): 31.0 12.1
Pwr(dBm): 1.0 12.4
Max(Kbps): 15672 692
Any possibility LVSKEM being included in the trails????
