ADSL2+? So....what is my max broadband speed?
- ADSL2+? So....what is my max broadband speed?
21-05-2012 9:19 PM
MAAF Speed tests indicate about 5Meg.
However, the BT website speed tester for my line says I can get the following:
Between 8.5Mb and 19.0Mb
(Estimated speed: 15.0Mb)
Router stats:
Modem Status Connected
DownStream Connection Speed 7616 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
ADSL Link Downstream Upstream
Connection Speed 7616 kbps 448 kbps
Line Attenuation 26.0 db 15.0 db
Noise Margin 13.0 db 23.0 db
Colour me confused?!
My exchange is EMROTHW - might be upgraded to ADSL2+ by now...not certain though!
Re: ADSL2+? So....what is my max broadband speed?
21-05-2012 9:30 PM
BT have announced a ready for service date for this exchange. The estimated go live date is between 20th April 2012 and 31st May 2012.
So it should be happening soon if it hasn't already.
A member of staff may be able to help tomorrow
21-05-2012 9:35 PM
22-05-2012 12:47 PM
23-05-2012 9:22 AM
Quote from: _Adam_Walker_ Hi moley, you're all set for an upgrade to ADSL 2 on 8/6/12
Great, can't wait Do I need to do anything after that date regarding profile etc.
23-05-2012 4:47 PM
08-06-2012 3:16 PM
ADSL LinkDownstream Upstream
Connection Speed 16752 kbps 440 kbps
Line Attenuation 28.5 db 12.4 db
Noise Margin 6.3 db 29.5 db
BT Speedtest shows:
Download speedachieved during the test was - 2.63 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 14.78 Mbps
I understand there is a 10 day 'training' period. Do I just need to be patient while my profile updates itself?
08-06-2012 4:37 PM
Sorry for the delay, we needed to update your connection speed and profile on our side. That's now been done for you, so you should be seeing improved speeds very shortly - please let us know if not.
09-06-2012 4:55 PM
BT speedtest says...
Download speedachieved during the test was - 8.98 Mbps
A good improvement by going to ADSL2+ (dare I say maybe a bit less than I had hoped though?
10-06-2012 1:34 PM
http://www.kitz.co.uk/adsl/max_speed_calc.php
I would also add that when I switched to the PN router, my speed took a spike upwards from 18.50 approx. to 2088 approx, proving to me that my router was the issue
11-06-2012 4:14 AM
11-06-2012 11:59 AM
