ADSL2+ Rejected by BT?
- ADSL2+ Rejected by BT?
01-02-2012 12:21 PM
The BT checker says "Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 3Mbps" so as I understand it, it should be available.
Speeds have improved since but definitely no ADSL2+, today have spoken to another support person who told me the request had been "Rejected" but he was unable to give a reason for this.
I have now read this post: http://community.plus.net/forum/index.php/topic,97728.0.html with regard to automated requests for ADSL2+ being rejected by BT.
So my question is, was my request an automated one and is this why it failed? If so could somebody be kind enough to place a manual order on the line for me?
Thanks very much in advance.
Basil Brooks
Re: ADSL2+ Rejected by BT?
01-02-2012 1:19 PM
I've submitted a manual order with reference 1-10711084666 which should complete within 7 days.
01-02-2012 1:31 PM
Potentially good news then, thanks very much for investigating and the quick turnaround on that.
All the Best
Basil Brooks
01-02-2012 1:32 PM
01-02-2012 2:12 PM
01-02-2012 8:05 PM
Even better, saves me connecting to the router to check.
Thanks a lot
Basil
02-02-2012 11:11 AM
02-02-2012 12:44 PM
Thanks again, I'll check around then.
02-02-2012 2:42 PM
09-02-2012 9:40 AM
My router (BT Home Hub 2) now shows the following:
Connection information
Line state Connected
Connection time 0 days, 10:45:13
Downstream 1,998 Kbps
Upstream 440 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.3
Latency type Interleaved
Noise margin (Down/Up) 15.8 dB / 12.0 dB
Line attenuation (Down/Up) 55.5 dB / 33.7 dB
Output power (Down/Up) 0.0 dBm / 12.9 dBm
The modulation type is now ITU-T G.992.3 as opposed to ITU-T G.992.1 previously
This indicates ADSL2 but not ADSL2+ according to this page http://en.wikipedia.org/wiki/G.992.3
Am a bit concerned by the Output power (Down) showing 0.0dBm, does this indicate a fault? anybody got any thoughts on that?
Here is what I had before the upgrade:
Connection time 0 days, 0:05:21
Downstream 2,176 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Noise margin (Down/Up) 14.8 dB / 17.0 dB
Line attenuation (Down/Up) 58.0 dB / 31.5 dB
Output power (Down/Up) 18.1 dBm / 12.1 dBm
As far as download speed goes I was getting about 1.3Mbps and am now getting 1.7Mbps so not as much increase as I had hoped for. This may improve over time during the "bedding in period" will have to see. Otherwise I guess that's the best I'm going to to get on copper and will have to look at FTTC for any further gains.
Thanks as always for your help and any further input.
Basil Brooks
09-02-2012 9:46 AM
http://www.kitz.co.uk/adsl/linestats_explanation.htm
This suggests my output power for ADSL2+ should be around 18bBm, so don't know what's going on there?
09-02-2012 9:49 AM
The actual figure will be around 19dB for a longish line
Short lines have the power cut back as they don't need it and it reduces cable cross talk(line to line interference in the same cable bundle)
Your line is too long to benefit from full ADSL2+ and experience has shown that putting such lines on 2+ regardless seems to result in a WORSE connection.
09-02-2012 9:53 AM
http://community.plus.net/forum/index.php/topic,102222.0.html
09-02-2012 9:54 AM
09-02-2012 10:05 AM
