ADSL2+ Line Upgrade
- ADSL2+ Line Upgrade
ADSL2+ Line Upgrade
18-05-2012 3:16 PM
Quote Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 8Mbps; typically the line speed would range between 7Mbps and 8Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 17Mbps; typically the line speed would range between 10Mbps and 19.5Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1.5Mbps and downstream line speed of 17Mbps; typically the downstream speed would range between 10Mbps and 19.5Mbps.
From Samknows RFS date is 31/5/12.
So any chance of a push to an upgrade?
Thanks!!
Re: ADSL2+ Line Upgrade
18-05-2012 5:28 PM
21-05-2012 11:05 AM
The order has now been placed for you, it's due to complete a week today on the 28th
Hope that helps.
21-05-2012 5:15 PM
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 1Mbps; typically the line speed would range between 1Mbps and 3.5Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 2.5Mbps; typically the line speed would range between 1.5Mbps and 4Mbps.
That estimated ADSL Max broadband line speed is too pessimistic; I'm actually getting 7616 kbps downstream.
But what of ADSL2+ broadband line speeds? According to SamKnows, 21CN WBC has been enabled on my exchange, so is it worth me trying it?
21-05-2012 5:25 PM
21-05-2012 5:31 PM
Quote ADSL Link Downstream Upstream
Connection Speed 7616 kbps 448 kbps
Line Attenuation 40.5 db 26.0 db
Noise Margin 6.0 db 23 db
21-05-2012 5:39 PM
21-05-2012 5:46 PM
Excuse my ignorance but what does capped upstream mean?
21-05-2012 6:41 PM
HTH.
21-05-2012 7:06 PM
So, could some kind Plusnet person please arrange for me to get an upgrade to ADSL2+.
21-05-2012 7:20 PM
So I wonder if at the moment the sync is limited by the line conditions - or by the router/modem unit
I hope the router is compatible with ADSL2+.................
21-05-2012 8:46 PM
My router does indeed support ADSL2+ although I have never had the opportunity to test it.
23-05-2012 11:45 AM
The order's been placed for you, it'll complete on the 30th
29-05-2012 6:08 PM
29-05-2012 9:14 PM
Post on the end of this thread
http://community.plus.net/forum/index.php/topic,101517.272.html
Its a common problem - I had it as have the 18 pages of other posters on it.
The line has been upgraded but Plusnet need to give their side of the system a kick to align their IP setting with the BT one.
That said they may wish to wait a day plus before they do it to let the new sync speeds stablise.
often 21CN/BT's system doesn't seem to send though the correct data to Plusnet even after the line is fully operational - it's a long running saga so I won't bore you.......
As for the Plusnet IP seting to be aligned
