ADSL2+ DLM Question
- ADSL2+ DLM Question
ADSL2+ DLM Question
06-11-2012 11:45 AM
Hi.
Had my connection for around a month which DLM quickly dropped to a 3db fast path profile, syncing around 22Mbit with attenuation of 17db.
Last week I tried a new router after which the noise margin rose to 6db and then 9db with interleaving also being applied. This led to a loss of 4Mb download speed.
Not sure why this happened as was careful to avoid multiple disconnects and didn't see any problems on my latency graphs.
I ran router stats for 24 hours and margin didn't vary from 9db by more than 0.2db. No packet loss or latency problems.
Is DLM likely to drop me back to 3db fast path over time or will it require some kind of reset to trigger the process?
Also if I ask for interleaving to be set to off will this interfere with DLM and the lowering of the noise margin?
Called support who offered to switch off 'Interleaving - Auto' but decided to leave things alone for now.
Gary
Gary
Message 1 of 8
(1,397 Views)
7 REPLIES 7
Re: ADSL2+ DLM Question
06-11-2012 1:15 PM
It does look like there were a few more disconnections than the one for the router change:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13522074758352.png" />
That'll be what's caused the drops. If the lower SNR is going to be restored it'll be a while, probably best to get the SNR reset but we wouldn't be happy about doing that until we've seen it stay stable for a couple of days. Let us know how it's gone later this week and we'll arrange that for you - we can look at removing interleaving at the same time.
Message 2 of 8
(645 Views)
06-11-2012 1:36 PM
OK. Thanks Matt.
Think all of those were probably me. Also been messing around getting bridging to work on the TG582.
Will leave well alone now and come back to you in a few days.
Gary
Gary
Message 3 of 8
(645 Views)
12-11-2012 9:37 AM
Hi Matt.
Would you be able to arrange the SNR reset now?
You should see 2 drops on the line since my last post.
One when DLM switched me back to fast path on the 7th and one where I rebooted my firewall and lost the PPPoE session on the 9th.
Does this restart the line training and can I expect a drop back down to 3db all being well?
Gary
Gary
Message 4 of 8
(645 Views)
12-11-2012 12:10 PM
Message 5 of 8
(645 Views)
12-11-2012 12:44 PM
Thanks Adam.
I can see a resync has taken place. I'll take a look when I get home.
Message 6 of 8
(645 Views)
12-11-2012 12:46 PM
Message 7 of 8
(645 Views)
17-01-2013 4:04 PM
Took a while for me to report back but was waiting to see what happened with the line just in case DLM works over periods of months
I was expecting a drop back down to 3db however the line has remained on 6db since the reset from which it never seems to vary by more than 0.2db.
Is there any way to trigger a drop back down to 3db?
My other slower line sits quite happily at this level.
Current stats for the line are:
Uptime: | 8 days, 18:45:56 |
DSL Type: | ITU-T G.992.5 |
Bandwidth (Up/Down) [kbps/kbps]: | 1.243 / 20.071 |
Data Transferred (Sent/Received) [GB/GB]: | 1,99 / 1,99 |
Output Power (Up/Down) [dBm]: | 12,8 / 0,0 |
Line Attenuation (Up/Down) [dB]: | 8,8 / 17,0 |
SN Margin (Up/Down) [dB]: | 5,9 / 6,1 |
System Vendor ID (Local/Remote): | TMMB / ---- |
Chipset Vendor ID (Local/Remote): | BDCM / IFTN |
Loss of Framing (Local/Remote): | 0 / 0 |
Loss of Signal (Local/Remote): | 0 / 0 |
Loss of Power (Local/Remote): | 0 / 0 |
Loss of Link (Remote): | - |
Error Seconds (Local/Remote): | 666 / 0 |
FEC Errors (Up/Down): | 0 / 0 |
CRC Errors (Up/Down): | 161 / 725 |
HEC Errors (Up/Down): | 81 / 1.582 |
Message 8 of 8
(645 Views)
