ADSL2 Connection has a worryingly low download snr- down to 0.1 at times
Gel
Seasoned Pro
Fixes: 13
SNR Dropped
My d/load snr is normally in 5-7 band.
That's changed today; any clues why?
It's been as low as 0.1!
0.8 this morning (7/6 @ 07.30)
Board version: Plusnet Hub One
5. DSL uptime: 1 days, 00:40:12
6. Data rate: 895 / 3619
7. Maximum data rate: 906 / 3508
8. Noise margin: 7.6 / 0.3
9. Line attenuation: 36.8 / 62.2
10. Signal attenuation: 36.6 / 57.9
Browni
Aspiring Hero
Fixes: 45
Re: ADSL2 Connection has a worrying low download snr
Noise on your phone line?
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Gel
Seasoned Pro
Fixes: 13
Fixes: 162
If it's not causing any issues I wouldn't worry too much about it. Let us know if you do start to have problems though.
 Chris Parr
 Plusnet Staff
Gel
Seasoned Pro
Fixes: 13
Thanks Chris; doesn't seem to be causing issues on my very long line.
Did go up to 3.3 earlier, but has dropped again now:
Fixes: 162
We can increase the target SNR to 6db, however that will very likely reduce the sync speed so unless you start to have issues I'm not really wanting to do it Smiley
 Chris Parr
 Plusnet Staff
Gel
Seasoned Pro
Fixes: 13
