ADSL1 on 21CN?
- ADSL1 on 21CN?
ADSL1 on 21CN?
18-10-2010 1:19 PM
Hello, can anyone help please?
I currently have a speed fault logged with PN support. I think its a problem with my Draytek Vigor 2800g router and adsl2+ compatibility. The connection does not stay stable for 2 or more days, and I have a banded profile applied to me due to this. I have tried different firmware for the draytek router but none seems stable. I have been sent a Thomson 585 to try which has been stable. I can only get 5mb / 6mb max (which I am happy with) where I live, what im asking is can I go back to adsl1 on 21CN? so I can use my draytek, as it has a USB port for my printer, and the Thomson does not. And I dont really want to buy a new router as I was fine before I moved to 21CN. or do I need to go back to dslmax so I can use the draytek for a stable connection?
Any ideas/ suggestions
Thanks very much
Thanks very much
Message 1 of 8
(1,343 Views)
7 REPLIES 7
Re: ADSL1 on 21CN?
18-10-2010 3:01 PM
HI FatP,
If you're dead set about using that router then if you wanted to go back to ADSL1 I'm sure we could arrange it; unless any of our fine forum members can think of anything to help.
Jojo
Jojo
Message 2 of 8
(590 Views)
Re: ADSL1 on 21CN?
18-10-2010 3:38 PM
Thanks Jojo, so it is possible to be on adsl1 on 21cn or is is adsl1 on dslmax?
Message 3 of 8
(590 Views)
Re: ADSL1 on 21CN?
18-10-2010 3:40 PM
I am on 21CN ADSL1 because I didn't ask/want to be upgraded
Message 4 of 8
(590 Views)
Re: ADSL1 on 21CN?
18-10-2010 3:45 PM
At a slower speed, such as 5Mb you are likely to be on ADSL2, which uses the same bandwidth as ADSL1.
It may even be an identical product.
ADSL2+ uses twice the bandwidth.
Message 5 of 8
(590 Views)
Re: ADSL1 on 21CN?
18-10-2010 3:48 PM
Quote from: FatP it is possible to be on adsl1 on 21cn or is is adsl1 on dslmax?
Yes you can go on ADSL1 on 21CN like Jim said. Just let us know if you want it doing?
Jojo
Message 6 of 8
(590 Views)
Re: ADSL1 on 21CN?
18-10-2010 8:59 PM
Thanks for the comments!
Im defo on ADSL2+ -
WBC 1M - 3M No delay (INP 0) 6dB Downstream, 448 No delay (INP 0) 9dB Upstream (ADSL2+)
I have emailed draytek tech support to see if they have anything to say about the unstable Vigor 2800 on ADSL2+, but I maybe back to ADSL1
Im defo on ADSL2+ -
Message 7 of 8
(590 Views)
Re: ADSL1 on 21CN?
18-10-2010 10:43 PM
Hi FatP,
Ok, well, keep me informed and I'll do what I can to help.
Jojo
Jojo
Message 8 of 8
(590 Views)
