ADSL very slow connection
prz3m3k
Hi there!
I know that is another topic of this type. However, I tried to resolve the situation after reading many topics but without success.
So I will describe my problem ...
Just returned from a 2 weeks holidays and noticed that my internet works very slowly ... sometimes I even have a problem with the opening of a web page ... before my holiday my internet speed  was generally from 3 to 5 Mbps.
Paste a couple of information which may help solve my problem ...
Unfortunately I do not have phone to check the noise...
Yesterday I talked with plusnet support on webchat and I heard: Ashley: The speed is showing as correct however I can see some errors on the line that could be causing this problem. It would be worth going through some checks and reporting the fault further"
I also tried to change ADSL Filter but nothing happend.
My router is Technicolor TG582n (got it from 2014)
DSL Connection
Link Information
Uptime: 0 days, 0:51:16
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,027 / 5,459
Data Transferred (Sent/Received) [MB/MB]: 29.11 / 219.14
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 24.8 / 45.0
SN Margin (Up/Down) [dB]: 6.6 / 7.3
Loss of Link (Remote): -
Error Seconds (Local/Remote): 3,032 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 3 / 146,777
HEC Errors (Up/Down): 1 / 755,256
And some ionformation from http://speedtest.btwholesale.com/
Download Speed (Mbps): 0.90
Upload Speed (Mbps): 0.81
Ping Latency(ms): 41.50
BT BROADBAND AVAILABILITY CHECKER
https://www.btwholesale.com/includes/adsl/main.html
Telephone Number 0117 on Exchange AVONMOUTH is served by Cabinet 31
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 5.5 -- 3 to 8 Available -- --
ADSL Max Up to 4 -- 3 to 7 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Other Offerings
Availability Date
ADSL Multicast -- -- -- Available -- --
 Moderator's note by Dick (Strat) Full telephone number removed from a public forum.
prz3m3k
Re: ADSL very slow connection
Plusnet Staff
Plusnet Staff
Fixes: 159
That speed test result, in conjunction with the line stats you've given is odd.
I've advise getting a fault reported at https://faults.plus.net so we can investigate further.
 Chris Parr
 Plusnet Staff
prz3m3k
I just did
Question #126313406
Fixes: 16
I think they may have skipped the actual speed test that time, and gone directly to the diagnostics page to get the IP profile, and so the speed test result shown is just some random number.
prz3m3k
After sending a ticket to support team iv got a lot of DC today.
And now after connecting to the internet it looks even worse than before...
DSL Connection
Link Information
Uptime: 0 days, 0:11:14
Bandwidth (Up/Down) [kbps/kbps]: 984 / 5,579
Data Transferred (Sent/Received) [MB/GB]: 586.74 / 2.27
Line Attenuation (Up/Down) [dB]: 24.9 / 45.0
SN Margin (Up/Down) [dB]: 5.8 / 8.6
Loss of Framing (Local/Remote): 126 / 0
Loss of Signal (Local/Remote): 14 / 0
Error Seconds (Local/Remote): 93,954 / 8
FEC Errors (Up/Down): 29,413 / 1,070,877
CRC Errors (Up/Down): 1,071 / 18,984
HEC Errors (Up/Down): 493 / 79,174
Download Speed (Mbps): 0.51
Upload Speed (Mbps): 0.77
Ping Latency(ms): 40.88
Plusnet Staff
Plusnet Staff
Fixes: 159
The mean time between errors on your line is at 1 second, so your line is erroring very very regularly.
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 24.8 45.0
SNR Margin: 6.5 10.3
Errored Seconds: 3 762
HEC Errors: 2
Cell Count: 11655601 120177288
Speed: 1016 5159
Maximum Stable Rate (KBPS): 21568 Fault Threshold Rate (KBPS): 17254
Mean Time Between Retrains (Seconds): 21159 Mean Time Between Errors Upstream (Seconds): 855
Indicative Line Quality: R Mean Time Between Errors Downstream (Seconds): 1
There are a huge amount of drops, especially yesterday on your line. This is not going to be helping at all. I'll respond to your fault ticket shortly.
 Chris Parr
 Plusnet Staff
prz3m3k
I do some ping www.google.com -t
100 attempts 21% lost
Fixes: 19
You really need t get your hands on a phone - it is an essential diagnostic tool necessary to confirm that you have a dial tone and no noise.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.
prz3m3k
I will try to borrow some phone and check it.
Anyway from about 3 days internet was much better few tests on http://www.speedtest.btwholesale.com/ was showing more than 4Mbps, yesterday and today speed drop again and its 2.9 Mbps
