ADSL speeds after upgrade to Fibre
freeallbadgers
Had fibre installed yesterday but I'm still getting ADSL speeds 2.3Mb/s down (the estimate was 38 Mb/s), but the upload has increased to 8-11 Mb/s
I've connected directly to the openreach modem via ethernet and its still the same  Angry
I
Fixes: 62
Re: ADSL speeds after upgrade to Fibre
This won't have updated https://portal.plus.net/my.html?action=data_transfer_speed
Give them a call
Fixes: 222
Probably needs an update to your profile, what's your current line speed in the member centre?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
freeallbadgers
Estimated line speed:
    38Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-09-26 04:50:03
Current line speed:
    2.3 Mb
Fixes: 222
As Jim says give them a call to get that updated
freeallbadgers
Ok will do, thanks for the quick replies.
