ADSL speed less than expected
maricla
As costumer center requested I unscrewed the socket!
What is next?
1 REPLY
Fixes: 46
Re: ADSL speed less than expected
Hi Maricla,
If you connect over WiFi as most do it would be worth connecting directly to the router with an network cable to test the speeds that way.
Keep us posted as to how you get on.
 Adam Walker
