ADSL on new style openreach fibre socket?
- ADSL on new style openreach fibre socket?
29-12-2012 11:06 AM
Just a quickie, I found my old Talktalk ADSL modem but can't find a microfilter anywhere.
Im having adsl provisioned on the line at the beginning of Jan while plusnet sort out problems with my fibre order.
Would it be safe to assume that a microfilter is still needed and the old ADSL modem is not going to work in the same socket as the fibre modem?
I figure it won't since them two wires drift off to the fibre cabinet rather than the exchange.
(trying to save myself having to hunt for the filter and pull out 50 drawers!)
Re: ADSL on new style openreach fibre socket?
29-12-2012 11:40 AM
ADSL modem plugs straight in to the RJ11
29-12-2012 2:00 PM
Quote from: GJenkins Hi there,
A couple of things there.
First, the wires from the VDSL2 socket don't go back to the fibre cabinet. Have a read of the RobertoS description of FTTC.
As the Openreach filter has been fitted, do you know what the problem was with completing the job? Usually the cabinet end described in that link is done before coming to you. (But maybe you had one of the Kelly/Quinn berks who couldn't open the PCP but continued to you to fit the filter?). So the engineer that connects the ADSLx is going to have to undo that and also connect to ADSLx at the exchange. Once that is done, then the modem socket the engineer fitted is fine for ADSLx. Just plug the ADSL cable in as normal for a filtered faceplate.
Is it Plusnet providing the ADSLx? If not, and they are still trying to sort out the FTTC, things are going to get verrryyy complicated.
29-12-2012 2:28 PM
The problem is that it is a reprovisioning but for some reason plusnet are being told that fibre isnt available in my area, since the line is already fibre capable and has been for over a year, the 'system' is clearly incorrect
According to plusnets suppliers, the workaround is to get ADSL activated first and then have a new fibre order.
But my main concern was how the old ADSL modem connects to a fibre enabled socket, wether it would plug in where the fibre plugs in, or the main phone socket. Made a quick call and it turns out that it has to be the main phone socket rather then the fibre one that is just above it.
29-12-2012 2:58 PM
Quote from: GJenkins Made a quick call and it turns out that it has to be the main phone socket rather then the fibre one that is just above it.
And who told you that?
29-12-2012 3:04 PM
There are technical differences between a fibre modem and an adsl modem which means that they are totally incompatible with each other. ADSL modems should only be plugged into the main phone socket via a filter, and the fibre modem only plug into the fibre socket on the faceplate. Makes sense to me!
Not that it matters - ive located a filter 😃
29-12-2012 3:15 PM
Can't see what that would be.
The filter separates the "High Band" ADSL or VDSL from the "Low Band" voice signals.
Note that the BT supplied "modem" does VDSL+ or can be configured to do ADSL on the same RJ11 connector.
http://www.clarity.it/vdsl_nte5_adaptor_faceplate.htm
http://www.clarity.it/telecoms/adsl_bandwidth.htm
As the high band has already been filtered from the voice socket...I will be surprised if you will get any ADSL signal there...
29-12-2012 3:36 PM
The Plusnet walla is talking rot. Needs "re-training".
To illustrate, (in the reverse context), many engineers installing FTTC and finding an existing filtered faceplate (from any reputable supplier) for ADSLx don't even bother with the new one. They would have to remove all extensions from the original filtered faceplate and reconnect them to a new NTE5A, then install that onto the new interstitial plate. For no good reason, so they don't.
29-12-2012 3:54 PM
Quote from: Estragon The VDSL faceplate is just a more easily fitted version of the old BT filtered faceplate.
Agreed.
I use one on my ADSL2+ connection; it's excellent.
29-12-2012 4:31 PM
29-12-2012 4:40 PM
It depends on whether the modem is set to train down to ADSLx from VDSL in it's default setup ...
goes to look at his unlocked modem...
... looks as though it is set to "All", so it should work.
29-12-2012 4:52 PM
Quote from: GJenkins Plusnet.
Somebody getting mixed up with fibre to the premises?
29-12-2012 4:56 PM
And quite possibly Jelv! Mind you, I don't think she was properly trained for tech support, she was was more sales than anything
02-01-2013 3:49 PM
I thought I'd give my old D-Link ADSL router a try as there was a DSL light on the OR fibre modem but it just wouldn't authorise my Netgear Router.
I unplugged the line from the OR modem and plugged it into the dlink (I was too lazy to shift a cupboard) and after updating the username and password, the modem connects perfectly well 😃
02-01-2013 3:53 PM
