ADSL loss of synch
- ADSL loss of synch
ADSL loss of synch
12-08-2007 2:26 PM
On Friday morning I experienced loss of ADSL synchronisation, raised a ticket (22563171) and went through the broadband checker, which (I believe) confirmed, yes, there was indeed a loss of synch, just as the blinking led on my modem/router was showing.
Support have said they have asked interleaving to be switched on, which may occur tomorrow, and then I have to wait for a further 48 hours before anything useful will be done.
I did not have stability issues with my connection, it had been absolutely fine until Friday morning, so interleaving is extremely unlikely to do anything useful and just gives a delay to getting BT to sort the problem out (as well as ping delays and slower speeds when it is sorted out).
This means at least a further 3 working days until the problem is actually addressed, on top of the existing 1 working day already, and how many more after that to actually fix it?
Can't you just get BT to do it now?
Message 1 of 7
(2,357 Views)
6 REPLIES 6
Re: ADSL loss of synch
12-08-2007 2:36 PM
Unfortunately BT don't work weekends though they will be working from midnight tonight - I'd say it'll be done first thing in the morning, and I'll make sure your ticket is with someone who can action it for you first thing tomorrow.
Message 2 of 7
(669 Views)
12-08-2007 2:46 PM
Thanks for the reply, very much appreciated.
Even if BT don't work weekends, getting a fault logged a.s.a.p. would be good.
Message 3 of 7
(669 Views)
12-08-2007 2:52 PM
No worries, apologies for the hassle.
As an aside...
If I had a pound for every time I've heard that, I'd have bought BT out just to stop hearing it
As an aside...
Quote Can't you just get BT to do it now?
Message 4 of 7
(669 Views)
12-08-2007 2:58 PM
Quote If I had a pound for every time I've heard that, I'd have bought BT out just to stop hearing it Wink
At a pound a go, you'd have been able to retire by now anyway
Message 5 of 7
(669 Views)
13-08-2007 11:04 AM
In the meantime I've heard from support who say they won't call BT until intervleaving has been switched on, and has been on for at least 48 hours.
They say the fault is intermittent, because on Friday 10th the adsl synched for some time.
I say the fault is *not* intermittent because all was fine until Friday and has been down since Friday.
Now I am on day 4 of the fault, I have to go 2 more days without ADSL before they will even put in a fault report to BT.
I think it's time to read up on how to go about getting my migration code
Message 6 of 7
(669 Views)
13-08-2007 12:15 PM
Apologies for the delay in getting this raised, it's now been passed to BT Wholesale for investigation, and hopefully they'll have it up and running for you soon.
Message 7 of 7
(670 Views)
