ADSL line status
- ADSL line status
ADSL line status
06-11-2010 5:29 PM
Does this all look ok ?
Actual speeds are roughly 7.5mbps down and 0.9mbps up.
Line state Connected
Connection time 0 days, 4:30:08
Downstream 10,827 Kbps
Upstream 1,063 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 3.9 dB / 6.5 dB
Line attenuation (Down/Up) 29.0 dB / 15.1 dB
Output power (Down/Up) 0.0 dBm / 12.3 dBm
Upstream 1,063 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Message 1 of 5
(1,133 Views)
4 REPLIES 4
Re: ADSL line status
06-11-2010 5:43 PM
Assuming you are on ADSL2 no they don't look OK - you should be getting quite a bit faster downstream sync
Can you try the test socket and report them again
Message 2 of 5
(545 Views)
06-11-2010 5:57 PM
My connection randomly drops (faulty copper in the street) so the sync
speed keeps changing.
It used to sync at around 13 and I would get 9.5
I will try the test socket but I feel Iam wasting my time if the
connection keeps dropping....
Message 3 of 5
(545 Views)
06-11-2010 6:10 PM
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
9030 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 9030 Kbps
For your connection, the acceptable range of speedsis 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :10827 Kbps(DOWN-STREAM), 1063 Kbps(UP-STREAM)
IP Profile for your line is - 8000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 18.51:23.14:58.35 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload Speed
874 Kbps
0 Kbps 1063 Kbps
>Upload speed achieved during the test was - 874 Kbps
Upstream Rate IP profile on your line is - 1063 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit FAQ section if you are unable To understand the test results.
Message 4 of 5
(545 Views)
06-11-2010 10:16 PM
Quote from: JasonE My connection randomly drops (faulty copper in the street) so the sync
I think you are right, you are wasting your time. If you know you have faulty copper in the street, why don't you get something done about it?
Message 5 of 5
(545 Views)
