ADSL filter
jeremygray
ADSL filter
I have just joined Plusnet and was previously with Talktalk. An enginer came a month ago to check the line and said we did not need filters on each telephone as we has a BT accelerator. Is this correct or should I use the filters ?
The broadfband and telephone seem to work fine without them.
apjashley1
Re: ADSL filter
EDIT
apjashley1
Re: ADSL filter
Quote from: apjashley1
He's correct. The filtering is done at the master socket if you've got two seperate outlets on the socket, one for ADSL and one for the phone.
jeremygray
Re: ADSL filter
That is most helpful -thank you.
Fixes: 20
Re: ADSL filter
if you've got two seperate outlets on the socket, one for ADSL and one for the phone....
... then you don't need filters but you don't have a BT Accelerator.  A BT Accelerator (formerly known as an i-Plate, item 2 in the picture here) does NOT obviate the need for filters.  Note in the picture there are NOT two separate outlets on the socket.
jeremygray
Re: ADSL filter
Noted many thanks
