ADSL dropping several times per day,
rpaco
After weeks of low speed and multiple disconnections a few weeks ago, The third BT/OR engineer did some proper line tests and told me that these frequent faults were usually because of old/unreliable equipment in the exchange. He did a "Lift and Shift" changed my line form the Cabinet to exchange and put me on different gear in the exchange. Brilliant ! Almost a month of full speed connection with only one drop.
Then I can only suppose another engineer fixed someone else's problem by nicking my good line to cab and exchange equipment. Over the last month it has been disconnecting several times a day. My once good speed had gradually fallen as the disconnections register on the auto quality/speed system.
I was seriously thinking of upgrading to FTTC but I am put off by the unreliability of the infrastructure.  My village has ad around 200-300 new houses built over the last 15 years with more being added each year. The exchange was built years before and is obviously at full capacity. Thus when a line fix is done for one it just moves the problem.   The FTTC cabinet is fairly new and while the route from there to my house must include the old cabinet I suppose the part to the exchange may be more reliable.  Yet I see many similar problems in the Fibre forum section!
I am beginning to fear that the only answer is via the mobile network such is the state of the BT/OR network.
(If you check in the BT forums you will see all the same complaints as are here.  (Yes we all know Plusnet is owned by BT)
BTW I am now down to around 0.4 up 5.5 down throughput. With disconnection 3 times a day on average.
I have just added a Belkin mains smoother to the router supply.
 Meanwhile can someone please run radius on my account and get the actual figure of disconnections.
Many thanks.
5 REPLIES 5
Fixes: 1,600
Re: ADSL dropping several times per day,
Thanks for your post @rpaco I'm sorry to see the connection problems have returned. Looking at your connection I can see there were a lot of drops earlier in the week, but things appear to have stabilised now.
Line tests are showing that your connection has stabilised because the software at the exchange is pushing your speed down in order to maintain stability so there's definitely a problem somewhere.
If the issue is the exchange equipment then if you were to go onto fibre, you shouldn't experience the same issues as in theory when you're on fibre, anything which impacts the service is between the cabinet and your property.
If you've carried out the usual troubleshooting steps like try the master socket and another router if you can, could you reply to this ticket I've raised, with your availability for an engineer to visit so we can investigate this further?
I'm taking this on personally moving forward so if we progress the fault and the issue isn't fixed after the 1st engineer in light of the issues you've had previously I'll be happy to get this escalated before potentially another engineer visit.
Apologies for the inconvenience caused.
rpaco
Hi thanks, I am a little puzzled as not all the drops are showing on the radius chart.
Here is the latest page of my modem log, WAN only.
I will try the Plusnet hub2 again (BT hub 5) but think this is a step down from my current BT hub6A.
A lot of the disconnects claim to be user disconnect or Restart configuration change!
I will reply to the ticket after trying the other modem/router, have to find it first!
This shows all events that have taken place on your BT Smart Hub since the last time it was reset.
Page 1 of 14
Category:
Time and date
Message
Selected:  WAN
18:07:08, 13 Dec.
:WAN: SENSING AUTO ADSL
18:06:59, 13 Dec.
atm0.35:connection ATM_TV connected
18:06:59, 13 Dec.
atm0.38:connection ATM_DATA connected
18:06:59, 13 Dec.
dsl:ADSL link Up: Down Rate=12392Kbps, Up Rate=984Kbps, SNR Margin Down=10.00dB, SNR Margin Up=5.60dB
18:04:40, 13 Dec.
:connection ATM_DATA disconnected.[ERROR_NO_CARRIER]
18:04:39, 13 Dec.
:connection ATM_TV disconnected.[ERROR_NO_CARRIER]
18:04:38, 13 Dec.
dsl:ADSL Link Down: duration was 12 seconds
18:04:26, 13 Dec.
18:04:26, 13 Dec.
18:04:26, 13 Dec.
dsl:ADSL link Up: Down Rate=12280Kbps, Up Rate=984Kbps, SNR Margin Down=10.10dB, SNR Margin Up=5.50dB
18:03:07, 13 Dec.
18:03:05, 13 Dec.
18:03:03, 13 Dec.
dsl:ADSL Link Down: duration was 148578 seconds
00:46:56, 12 Dec.
00:46:47, 12 Dec.
00:46:47, 12 Dec.
00:46:47, 12 Dec.
dsl:ADSL link Up: Down Rate=8576Kbps, Up Rate=424Kbps, SNR Margin Down=11.20dB, SNR Margin Up=6.10dB
00:46:02, 12 Dec.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:46:00, 12 Dec.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:45:59, 12 Dec.
dsl:ADSL Link Down: duration was 13 seconds
00:45:47, 12 Dec.
00:45:47, 12 Dec.
00:45:47, 12 Dec.
dsl:ADSL link Up: Down Rate=11712Kbps, Up Rate=928Kbps, SNR Margin Down=10.10dB, SNR Margin Up=5.40dB
00:45:28, 12 Dec.
00:45:26, 12 Dec.
00:45:25, 12 Dec.
dsl:ADSL Link Down: duration was 13757 seconds
00:35:17, 12 Dec.
20:56:18, 11 Dec.
20:56:09, 11 Dec.
20:56:09, 11 Dec.
20:56:08, 11 Dec.
dsl:ADSL link Up: Down Rate=11972Kbps, Up Rate=972Kbps, SNR Margin Down=10.00dB, SNR Margin Up=6.20dB
20:55:24, 11 Dec.
20:55:23, 11 Dec.
20:55:21, 11 Dec.
dsl:ADSL Link Down: duration was 22806 seconds
14:39:53, 11 Dec.
14:35:25, 11 Dec.
14:35:15, 11 Dec.
14:35:15, 11 Dec.
14:35:15, 11 Dec.
dsl:ADSL link Up: Down Rate=11548Kbps, Up Rate=908Kbps, SNR Margin Down=10.20dB, SNR Margin Up=6.10dB
14:34:31, 11 Dec.
14:34:29, 11 Dec.
14:34:28, 11 Dec.
dsl:ADSL Link Down: duration was 7215 seconds
00:01:25, 01 Jan.
00:01:14, 01 Jan.
00:01:14, 01 Jan.
00:01:14, 01 Jan.
dsl:ADSL link Up: Down Rate=12352Kbps, Up Rate=996Kbps, SNR Margin Down=9.90dB, SNR Margin Up=5.50dB
00:00:24, 01 Jan.
:WAN: ethernet as LAN
10:43:27, 11 Dec.
10:43:18, 11 Dec.
10:43:18, 11 Dec.
10:43:18, 11 Dec.
dsl:ADSL link Up: Down Rate=12432Kbps, Up Rate=984Kbps, SNR Margin Down=9.90dB, SNR Margin Up=5.60dB
10:42:58, 11 Dec.
10:42:57, 11 Dec.
10:42:55, 11 Dec.
dsl:ADSL Link Down: duration was 31 seconds
10:42:33, 11 Dec.
10:42:24, 11 Dec.
10:42:24, 11 Dec.
10:42:24, 11 Dec.
dsl:ADSL link Up: Down Rate=11092Kbps, Up Rate=904Kbps, SNR Margin Down=10.40dB, SNR Margin Up=6.10dB
10:41:40, 11 Dec.
10:41:38, 11 Dec.
10:41:36, 11 Dec.
dsl:ADSL Link Down: duration was 11814 seconds
09:35:58, 11 Dec.
09:34:40, 11 Dec.
09:33:33, 11 Dec.
08:58:23, 11 Dec.
07:56:22, 11 Dec.
07:24:52, 11 Dec.
07:24:43, 11 Dec.
07:24:43, 11 Dec.
07:24:43, 11 Dec.
dsl:ADSL link Up: Down Rate=12056Kbps, Up Rate=960Kbps, SNR Margin Down=10.00dB, SNR Margin Up=5.40dB
07:24:23, 11 Dec.
07:24:22, 11 Dec.
07:24:21, 11 Dec.
07:24:09, 11 Dec.
07:24:09, 11 Dec.
07:24:09, 11 Dec.
dsl:ADSL link Up: Down Rate=12060Kbps, Up Rate=936Kbps, SNR Margin Down=10.10dB, SNR Margin Up=5.40dB
07:23:49, 11 Dec.
07:23:47, 11 Dec.
07:23:46, 11 Dec.
dsl:ADSL Link Down: duration was 37417 seconds
21:00:19, 10 Dec.
21:00:09, 10 Dec.
21:00:09, 10 Dec.
21:00:09, 10 Dec.
dsl:ADSL link Up: Down Rate=12288Kbps, Up Rate=984Kbps, SNR Margin Down=9.90dB, SNR Margin Up=5.40dB
20:59:49, 10 Dec.
20:59:48, 10 Dec.
20:59:47, 10 Dec.
20:59:35, 10 Dec.
20:59:35, 10 Dec.
20:59:35, 10 Dec.
dsl:ADSL link Up: Down Rate=12272Kbps, Up Rate=984Kbps, SNR Margin Down=9.90dB, SNR Margin Up=5.40dB
20:59:15, 10 Dec.
20:59:14, 10 Dec.
20:59:12, 10 Dec.
dsl:ADSL Link Down: duration was 12322 seconds
17:34:04, 10 Dec.
17:33:50, 10 Dec.
17:33:50, 10 Dec.
17:33:50, 10 Dec.
dsl:ADSL link Up: Down Rate=12384Kbps, Up Rate=984Kbps, SNR Margin Down=9.90dB, SNR Margin Up=5.50dB
17:33:31, 10 Dec.
17:33:29, 10 Dec.
17:33:27, 10 Dec.
dsl:ADSL Link Down: duration was 18102 seconds
14:38:32, 10 Dec.
Fixes: 1,600
Thanks for getting back to me @rpaco
There are some types of drops that our radius logs don't pick up on, although that's more common on fibre. We don't see that very often on a standard broadband connection.
Let me know your troubleshooting goes.
rpaco
Plugged into master socket using plug in filter/splitter as the official new (fitted last summer on first engineer visit )  dual output master socket with integral filter seems a bit loose on one side.
New DSL drop this morning 03:32 when only our cats may have been awake:
04:52:16, 14 Dec.
BR_LAN:The DHCP options that are offered by the device (id:3): DiscoverOptions: 53,61,57,55,60 | DiscoverOption55: 1,3,6,12,15,28,42 | RequestOptions: 53,61,50,54,57,55,60 | RequestOption55: 1,3,6,12,15,28,42 | HostName: | VendorId: udhcp 1.18.5.18.5
04:52:16, 14 Dec.
:DHCP Confirmation of Request
04:52:09, 14 Dec.
wl1:A WiFi device <34:38:B7:1E:0D:3B> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
04:51:34, 14 Dec.
wl1:Device <34:38:B7:1E:0D:3B> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
04:50:40, 14 Dec.
BR_LAN:The DHCP options that are offered by the device (id:2): DiscoverOptions: 53,57,60,12,55 | DiscoverOption55: 1,33,3,6,15,28,51,58,59,43 | RequestOptions: 53,57,60,12,55 | RequestOption55: 1,33,3,6,15,28,51,58,59,43 | HostName: Ulefone_Armor_5 | VendorId: android-dhcp-8.1.0
04:50:39, 14 Dec.
04:46:58, 14 Dec.
04:46:58, 14 Dec.
04:46:52, 14 Dec.
03:33:31, 14 Dec.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
03:33:30, 14 Dec.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
03:33:30, 14 Dec.
ppp1:TR69 receiving InformResponse message
03:33:30, 14 Dec.
ppp1:TR69 event found : 4 VALUE CHANGE
03:33:29, 14 Dec.
ppp1:TR69 sending Inform message
03:33:28, 14 Dec.
03:33:27, 14 Dec.
03:33:26, 14 Dec.
ppp1:TR69 creating new session with ACS
03:33:21, 14 Dec.
ppp1:New DYN ROUTE is added [212.159.6.9/32 gw 195.166.130.250]
03:33:21, 14 Dec.
03:33:21, 14 Dec.
ppp1:New DYN ROUTE is added [212.159.6.10/32 gw 195.166.130.250]
03:33:21, 14 Dec.
ppp1:PPP: PPP INFO 212.159.6.10,212.159.6.9
03:33:20, 14 Dec.
ppp:PPP: IPCP_NAK
03:33:20, 14 Dec.
ppp:PPP: CHAP_SUCCESS
03:33:20, 14 Dec.
ppp:PPP: CHAP_RESPONSE
03:33:20, 14 Dec.
ppp:PPP: LCP_GOOD_ACK
03:33:20, 14 Dec.
ppp:PPP: LCP_REQUEST
03:33:20, 14 Dec.
03:33:20, 14 Dec.
03:33:17, 14 Dec.
03:33:11, 14 Dec.
03:33:11, 14 Dec.
03:33:11, 14 Dec.
dsl:ADSL link Up: Down Rate=12392Kbps, Up Rate=1052Kbps, SNR Margin Down=6.90dB, SNR Margin Up=5.60dB
03:32:52, 14 Dec.
03:32:50, 14 Dec.
ppp1:The DYN ROUTE [212.159.6.9/32 gw 195.166.130.253] is deleted
03:32:50, 14 Dec.
ppp1:The DYN ROUTE [212.159.6.10/32 gw 195.166.130.253] is deleted
03:32:50, 14 Dec.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
03:32:50, 14 Dec.
03:32:49, 14 Dec.
dsl:ADSL Link Down: duration was 24929 seconds
02:04:42, 14 Dec.
01:54:20, 14 Dec.
BR_LAN:The DHCP options that are offered by the device (id:3): DiscoverOptions: 53,61,57,55,60 | DiscoverOption55: 1,3,6,12,15,28,42 | RequestOptions: 53,61,57,55,60 | RequestOption55: 1,3,6,12,15,28,42 | HostName: | VendorId: udhcp 1.18.5.18.5
04:52:16, 14 Dec.
04:52:16, 14 Dec.
04:52:09, 14 Dec.
04:51:34, 14 Dec.
04:50:40, 14 Dec.
04:50:39, 14 Dec.
04:46:58, 14 Dec.
04:46:58, 14 Dec.
04:46:52, 14 Dec.
03:33:31, 14 Dec.
03:33:30, 14 Dec.
03:33:30, 14 Dec.
03:33:30, 14 Dec.
03:33:29, 14 Dec.
03:33:28, 14 Dec.
03:33:27, 14 Dec.
03:33:26, 14 Dec.
03:33:21, 14 Dec.
03:33:21, 14 Dec.
03:33:21, 14 Dec.
03:33:21, 14 Dec.
03:33:20, 14 Dec.
ppp:PPP: IPCP_NAK
03:33:20, 14 Dec.
03:33:20, 14 Dec.
03:33:20, 14 Dec.
03:33:20, 14 Dec.
03:33:20, 14 Dec.
03:33:20, 14 Dec.
03:33:17, 14 Dec.
03:33:11, 14 Dec.
03:33:11, 14 Dec.
03:33:11, 14 Dec.
03:32:52, 14 Dec.
03:32:50, 14 Dec.
03:32:50, 14 Dec.
03:32:50, 14 Dec.
03:32:50, 14 Dec.
03:32:49, 14 Dec.
02:04:42, 14 Dec.
01:54:20, 14 Dec.
Do BT/OR reboot the lines every night?
Further
Have checked with my neighbour on same BT pole and they are on BT fibre getting 50Mbps with no problems. So I will look at changing to them. I have BT phone and the BT phone/FTTC package is I think cheaper than yours inc line rental. I make very few phone calls and then normally within the weekend when they are free. Otherwise  have 1p mobile which is v cheap.
Fixes: 1,600
Thanks for getting back to us @rpaco
It’s not uncommon for Openreach to carry out maintenance in the early hours of a morning so the drops then may just be down to that.
If your neighbour is having no issues on fibre then that hopefully suggests you won’t either assuming that the issue with standard broadband is the exchange equipment not your phone line.
If you’re thinking of leaving, I’d recommend calling our customer options team on 0800 013 2632 to see what we can do for you in terms of a deal as the fibre service you’d get from BT will be similar to us apart from the router we offer although it looks like you’ll be using your own router anyway, and I’m sure we’d be able to tempt you with a good deal if you bring your phone over to us.
