ADSL dropping every 30 minutes?
- ADSL dropping every 30 minutes?
18-08-2015 4:51 PM
What I'm a bit confused about is that the new router stats make it seem as if our ADSL link is dropping and reconnecting every 30 minutes or so. Is there any way I can confirm this because I haven't noticed any issues since swapping I think!
Re: ADSL dropping every 30 minutes?
18-08-2015 7:43 PM
Maybe try this - is that your router mentioned in the list ( may be similar and work anyway)
http://www.s446074245.websitehome.co.uk/routers.html
19-08-2015 12:00 AM
ADSL Training Status: Showtime
Mode: ADSL2+
Traffic Type: ATM Mode
Link Uptime: 0 day: 4 hours: 15 minutes
ADSL Port Details Upstream Downstream
Line Rate: 0.895 Mbps 13.397 Mbps
Actual Net Data Rate: 0.888 Mbps 13.365 Mbps
Trellis Coding: ON ON
SNR Margin: 14.4 dB 9.4 dB
Actual Delay: 8 ms 8 ms
Transmit Power: 12.1 dBm 0.0 dBm
Receive Power: 4.7 dBm 4.7 dBm
Actual INP: 2.0 symbols 1.0 symbols
Total Attenuation: 0.0 dB 0.0 dB
Attainable Net Data Rate: 0.888 Mbps 14.556 Mbps
ADSL Counters
Downstream Upstream
Since Link time = 15 min 47 sec
FEC: 226 3
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 1 min 42 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 9 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 4 hours 16 min 42 sec
FEC: 226 3
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 54 54
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Total time = 4 hours 16 min 42 sec
FEC: 226 3
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 54 54
LOS: 0 0
LOF: 0 0
LOM: 0 0
Using these settings to connect to PN
WAN Configuration
Active
Name Broadband
Type ADSL over ATM
Mode Routing
Encapsulation PPPoA
IPv6/IPv4 Mode IPv6/IPv4 DualStack
ATM PVC Configuration
VPI [0-255] 0
VCI [32-65535] 38
DSL Link Type PPPoA
Encapsulation Mode VC/MUX
Service Category UBR Without PCR
PPP Information
PPP Username xxxxx@plusdsl.net
PPP Password xxxxxxx
PPP Trigger Type Auto Connect
IDLE Timeout [minutes] 5
IP Address
Obtain an IP Address Automatically Yes
Static IP No
IP Address N/A
Subnet Mask N/A
Gateway IP Address N/A
Routing Feature
NAT Enable Yes
Fullcone NAT Enable No
IGMP Proxy Yes
Apply as Default Gateway Yes
DNS Server
DNS Dynamic
DNS Server 1 N/A
DNS Server 2 N/A
IPv6 Address
IPv6 Address Automatic
Get IPv6 Address From DHCPv6 Server(IA_NA) No
Prefix Delegation(IA_PD) No
IPv6 Routing Feature
MLD Proxy Enable No
IPv6 DNS Server
IPv6 DNS Dynamic
IPv6 DNS Server 1 N/A
IPv6 DNS Server 2 N/A
QoS
Rate limit N/A
WAN Outgoing Default Tag DIsable
DSCP [0-63] N/A
MTU [68-1492] 1492
Bridge and Routing mode in the same WAN
Enable Con-current WAN No
19-08-2015 10:56 AM
Our tests aren't showing any issues.
I'd recommend raising it to us here.
https://faults.plus.net
19-08-2015 11:14 AM
Wow - you did give a hammering on saturday but not too bad since (not every half hour??)
Not sure all your settings are correct maybe look at the IPv6 bits in case there is a conflict
Here is a FIBRE set up but may help as that is for IPv4 setup as well
http://www.kitz.co.uk/routers/zyxel_VMG8324-B10A_vdsl_setup.htm
19-08-2015 1:17 PM
Mode: ADSL2+
Link Uptime: 0 day: 17 hours: 31 minutes
SNR Margin: 14.4 dB 9.3 dB
Attainable Net Data Rate: 0.888 Mbps 14.456 Mbps
ADSL Counters
Downstream Upstream
Since Link time = 31 min 13 sec
FEC: 1101 3
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 2 min 8 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 49 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 17 hours 32 min 8 sec
FEC: 1101 3
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 54 54
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Total time = 17 hours 32 min 8 sec
FEC: 1101 3
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 54 54
LOS: 0 0
LOF: 0 0
LOM: 0 0
I think I may have isolated the fauly. I had a 582n in use as an access point. I disconnected it from the network with this router at 7.45pm yesterday and no drops yet. So either it's that, or could a bad cat 5e cause bad enough issues to drop connection completely?
I might hold off on raising a fault just yet, I'll keep you posted on how it goes over the next few days.
19-08-2015 1:39 PM
Quote from: aj007 Link Uptime: 0 day: 4 hours: 15 minutes
Quote from: aj007 Link Uptime: 0 day: 17 hours: 31 minutes
ADSL Counters
I suspect it's just not printing all values for the "Since Link time" under the "ADSL Counters" section. It only seems to be printing only the minutes and seconds. But the FEC counts since link time are the same as for the total time (in these particular instances).
19-08-2015 2:00 PM
Quote from: ejs
ADSL Counters
Excellent, thanks mate
19-08-2015 8:11 PM
Mode: ADSL2+
Link Uptime: 1 day: 0 hour: 28 minutes
SNR Margin: 14.5 dB 9.2 dB
Attainable Net Data Rate: 0.888 Mbps 14.404 Mbps
ADSL Counters
Downstream Upstream
Since Link time = 28 min 27 sec
FEC: 2588 566
CRC: 1 2
ES: 1 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 14 min 23 sec
FEC: 1 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 112 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 29 min 23 sec
FEC: 113 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 2475 566
CRC: 1 2
ES: 1 1
SES: 0 0
UAS: 54 54
LOS: 0 0
LOF: 0 0
LOM: 0 0
Total time = 1 days 29 min 23 sec
FEC: 2588 566
CRC: 1 2
ES: 1 1
SES: 0 0
UAS: 54 54
LOS: 0 0
LOF: 0 0
LOM: 0 0
19-08-2015 10:24 PM
This may take a day or two to get back, maybe PN can intervene and reduce them
but they like to see a period of stability first. I personally would leave it until the weekend
and if no improvement try a resync during the day around 14.00 2pm but not after 7pm.
Others who understand the stats better may a different view.
Funnukly enough I did a search on your 888 upload spead and your post from 2 years ago came up.
19-08-2015 11:11 PM
Strange that those stats aren't returning the Attenuation - can't deduce what sync speed you might be able to achieve.
How exactly did you have the 582n connected as an AP? It might be best to resolve that issue before an SNR Reset so as to avoid upsetting DLM after the reset.
20-08-2015 12:30 AM
So I've got two cat 5e cables running from my modem router to the attic. One terminates there into a ZyXEL 16 port switch, the other continues to the other side of our house plugging into the first ethernet port of the 582n. I set it up by disabling IPv4 and IPv6 DHCP.
Anyway, since it's been disconnected on late Tuesday night, the router doesn't report any drops, nor have I noticed any. I'm not planning on reusing the uselss 582n which is now confined to electronic recycling I'll test the run of cable that was supplying it but in all likelihood, I'll tear it out and replace it with a new run just to be safe.
20-08-2015 2:00 AM
20-08-2015 12:56 PM
Another update, here are the stats from DSLStats:
Stats recorded 20 Aug 2015 12:55:05
DSLAM/MSAN type: IFTN:0x71c8 / v0x71c8
Modem/router firmware: AnnexA version - A2pv6F039i.d24e
DSL mode: ADSL2+
Status: Showtime
Uptime: 1 day 17 hours 13 min 23 sec
Resyncs: 0 (since 20 Aug 2015 12:51:33)
Downstream Upstream
Line attenuation (dB): 23.5 12.7
Signal attenuation (dB): Not monitored
Connection speed (kbps): 13365 888
SNR margin (dB): 9.2 14.4
Power (dBm): 0.0 12.1
Interleave depth: 64 8
INP: 1.00 2.00
G.INP: Not enabled
RSCorr/RS (%): 0.0003 0.0284
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0
And pulled these from telnet
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 8000
Last initialization procedure status: 0
Max: Upstream rate = 888 Kbps, Downstream rate = 14444 Kbps
Bearer: 0, Upstream rate = 888 Kbps, Downstream rate = 13365 Kbps
Link Power State: L0
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Down Up
SNR (dB): 9.2 14.4
Attn(dB): 23.5 12.7
Pwr(dBm): 0.0 12.1
ADSL2 framing
Bearer 0
MSGc: 59 10
B: 206 13
M: 1 8
T: 2 9
R: 14 16
S: 0.4944 4.0000
L: 3576 256
😧 64 8
Counters
Bearer 0
SF: 9233243 788075
SFErr: 2 2
RS: 1200321343 2374198
RSCorr: 4054 675
RSUnCorr: 2 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 381755717 310497259
Data Cells: 337456328 20819672
Drop Cells: 0
Bit Errors: 100 113
ES: 2 1
SES: 0 0
UAS: 54 54
AS: 148404
Bearer 0
INP: 1.00 2.00
INPRein: 0.00 0.00
delay: 8 8
PER: 16.06 18.00
OR: 32.36 7.11
AgR: 13345.73 892.51
Bitswap: 216/216 5/5
Total time = 1 days 17 hours 14 min 18 sec
FEC: 4054 675
CRC: 2 2
ES: 2 1
SES: 0 0
UAS: 54 54
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 14 min 18 sec
FEC: 111 102
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 414 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 17 hours 14 min 18 sec
FEC: 1579 109
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 2475 566
CRC: 1 2
ES: 1 1
SES: 0 0
UAS: 54 54
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 1 days 17 hours 13 min 23 sec
FEC: 4054 675
CRC: 2 2
ES: 2 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Out of interest, how does PN determine the line speed? I just ask because I've been posting on kitz about some other networking stuff and came across the max speed calculator tool
20-08-2015 1:13 PM
Do you have a Master Socket similar to the one on the left?
Do you have any extension phone sockets, and what is normally plugged in where? Are you using any plug-in extension phone/router leads?
Do all your Microfilters look similar to this?
