ADSL customer 12M can I upgrade to a fibre package on 12M
ware90
Hi I'd like to upgrade to 12M Fibre not 18M, previously I did this many years ago is this possible to upgrade from ADSL 12M to Fibre Extra 12M and not 18M
Kind regards
6 REPLIES 6
Legend
Fixes: 254
Re: ADSL customer 12M can I upgrade to a fibre package on 12M
@ware90 I don't quite understand the question. Fibre packages are either Unlimited Fibre (40/10) or Unlimited Fibre Extra (80/20). If you post the results of BT Broadband (obscuring your phone number) we could explain your options.
Fixes: 48
@ware90
Do you mean 12 months as opposed to 18 months?
Legend
Fixes: 254
Ah, never thought of that, @bmc - thanks. If that is the case, the OP probably needs to ring retentions.
ware90
Hi apologies, am awaiting a plusnet staff to answer this also,
Yes I'm on a 12 momth ADSL
I'd like to upgrade to Fibre 66mbps
But on a 12 month C, which I'm currently on with ADSL online system only offering me 18M, previously years ago I managed to upgrade from ADSL 12month to Fibre 12Month.
Regards
Fixes: 417
@ware90
Ring the Customer Options Team on 0800 013 2632 and tell them what you want with the alternative of you moving on. You can't do it on this forum.
LaurenB
Fixes: 131
Hiya @ware90, thanks for getting in touch. I am really pleased you are looking to renew with us Smiley
As the other users have mentioned if you give our customer options team a call (on the number @Baldrick1 has kindly provided above) the team will be able to assist with this for you.
Please just get back to us should you have any further queries.
 Lauren Barry
