ADSL connection keeps dropping
- ADSL connection keeps dropping
19-10-2012 8:54 PM
Down:
SNR 0
Attenuation 43db
11705 Kbps
Up:
SNR 6
Attenuation 25
1106 kbps
Re: ADSL connection keeps dropping
19-10-2012 9:28 PM
Which routers have you tried?
Are there any extensions wired in to the master socket?
19-10-2012 10:22 PM
20-10-2012 8:08 AM
It's odd that your fault is not self-correcting. When you disconnect a router I would expect the SNR to go up to a more reasonable value when you reconnect.
21-10-2012 5:15 PM
On the other hand, we've just got back from a weekend away and the router is showing the downstream SNR margin as 4db with the connection up for over a day. Thanks for the help anyway!
21-10-2012 5:36 PM
4db certainly sounds a bit better, but the current stats will give a better idea. Oh, and welcome to the forum.
21-10-2012 6:24 PM
Down:
SNR margin 3.6 db
Attenuation 43 db
10391 Kbps
Up:
SNR margin 5.1 db
Attenuation 25 db
1117 kbps
21-10-2012 11:41 PM
Now, can you clarify what hard-wired sockets you have? I deduce that your incoming BT cable goes to one old style socket (master socket) but because you said "I've tried connecting directly into the master socket" this suggests you have at least one other, but then you said "It looks like none of the extensions are connected any more"
Can you explain how you are normally connected and what you have plugged in? Are you using any extension leads?
I guess your Master Socket may look like the middle picture, and do your Microfilters that look like this ?
22-10-2012 3:12 PM
Looks like things are much more stable now:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13509150946997.png" />
Hope things keep up that way, especially if you're still getting the same speeds with the same downstream SNR
22-10-2012 3:24 PM
Stats from daylight hours and late this evening as well would still be good to see.
23-10-2012 9:46 AM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13509818487265.png" />
23-10-2012 11:11 AM
Quote from: Anotherone That looks a bit healthier. Can you post another sets from daylight hours tomorrow. I hope the connection hasn't dropped.
From late last night:
Down:
SNR margin 3.3 db
Attenuation 43 db
10391 Kbps
Up:
SNR margin 5.7 db
Attenuation 25 db
1117 kbps
From 8am today:
Down:
SNR margin 4.0 db
Attenuation 43 db
10391 Kbps
Up:
SNR margin 5.8 db
Attenuation 25 db
1117 kbps
The only connected socket is the master, which is indeed like the LJU one in your first link. I have a 10m extension cable which connects to a microfilter like in your second link.
Quote from: _Adam_Walker_ BT haven't reported any outages in the area but I think we're safe to say that what ever caused the issues seems to have stopped now.
Yeah, no more disconnections in the last couple of days. It'd be nice to know what caused/fixed it, but I'll settle for it just working again!
Cheers All!
23-10-2012 1:04 PM
23-10-2012 5:35 PM
23-10-2012 5:55 PM
