ADSL checker incorrect
ebostgriff
When will I be connected to fibre broadband?
The ADSL checker says that I am connected to Longton cabinet 18 and fibre is available.
I have had problems with fibre broadband since April and have been visited by 6 Openreach "engineers", to no avail. The last one told me that I was not connected to the cabinet, which is about 200 metres away, but am copper all the way to the exchange, about 1100 metres.
Plusnet have just reverted me to ADSL, and refunded my fibre broadband fees.
Some of my neighbours do have fibre, but for some reason Openreach took our cable past the cabinet without connecting it.
I can't ask Openreach directly, so when will I be connected to fibre broadband?
12 REPLIES 12
Fixes: 49
Re: ADSL checker incorrect
I'm assuming you mean  the following site when you say the ADSL checker.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
If you're in Lancs then the Codelook website has the following status of Cabinet P18
FTTC Available from 18th May 2017
If in Lancs then the status is
FTTC Available from 29th January 2014, being expanded by April 2018, some with 18/2M product
It's not unknown that OpenReach records can be updated incorrectly but you would have thought one of six engineers would have found this out. If you are on an Exchange Only line (EO) and the DSL checker is saying cab P18 then OpenReach records are wrong somewhere.
ebostgriff
Than you for your reply, Brian.
Yes, that is the checker which is wrong.
A long story, but basically:
Plusnet activated my fibre broadband on 14th March 1917. I was getting speeds of about 28 Mbs compared with the 14 I got on ADSL.
I immediately had problems with it constantly dropping out.
The speed was reduced to around 22 MBS which improved it slightly.
I had visits from 5 Openreach "engineers" who made not much difference. I gave up when I was told that my fibre would be upgraded soon.
Plusnet later told me that my fibre broadband would be upgraded on 6th September.
On that date I lost both phone and broadband.
After a week without them, "engineer" number 6 turned up. He thought it would be a quick job.
After a few hours, he restored my phone and told me that the problem was that on 6th September cabinet 18 was activated, which caused the loss of my supply.
He said that the cable for myself and a few neighbours, attached to one specific pole, was not connected to cabinet 18 but to a fibre cabinet 5 metres from the exchange, 1100 metres from my house.
He did not know if or when our cable would be connected to cabinet 18.
Plusnet reverted me to ADSL.
All I want to know is when I will be connected to fibre!!
Fixes: 49
If you're in Lancs then there is a capacity issue with P18 which isn't scheduled to be sorted until April next year.
If I remember correctly PlusNet can request a check on a line to confirm the path it takes to see if OpenReach records are wrong.
ebostgriff
Thanks again, Brian.
Yes, I am in Lancs.
I 'll have to be patient!!
Fixes: 1,600
I have raised a request [TAGs query] with our suppliers to investigate that.
It's difficult to say. We'd check the same resources as you; www.dslchecker.bt.com and https://www.homeandwork.openreach.co.uk/when-can-i-get-fibre.aspx
I've seen FTTP [Fibre To The Premises] become available before the regular FTTC service for exchange only lines, but we wouldn't be able to advise when that'd happen I'm afraid. Sad
Fixes: 49
@Gandalf
For information OpenReach have changed their website and your link no longer works. You need either of the following
https://www.openreach.co.uk/orpg/home/index.do
https://www.homeandbusiness.openreach.co.uk/fibre-broadband/when-can-i-get-fibre
The first link takes you to the second.
Fixes: 1,600
Thanks for the heads up!
ebostgriff
Thanks again, but it's still wrong, FTTC is not available on my line.
Fixes: 49
It was a website update, not their "database"
Fixes: 1,600
Sorry to resurrect this thread but I thought I'd update you here @ebostgriff
Our suppliers can confirm that your line is now routed through a fibre cab. If you'd like to give this another shot, I'd recommend calling Customer Options on 0800 013 2632 to place a fibre order.
Drop me a reply over here or a PM and I'll be happy to monitor the progress for you.
jelv
Fixes: 10
@ebostgriff
Wow - that is impressive - over 60 years before the Internet was invented! Cheesy
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Jonpe
Fixes: 9
Then the Russian revolution took place and it was suspended till the 1980s. Smiley
