ADSL broadband
danielmclean
ADSL broadband
what is the difference between fastpath and interleaving on adsl broadband Huh
28 REPLIES 28
Anotherone
Champion
Fixes: 21
Re: ADSL broadband
Interleaving provides a degree of error correction, but it also increases the ping (lag) time which can be a major nuisance for gamers.
What makes you ask, just learning or having a specific problem?
danielmclean
Re: ADSL broadband
was speaking to a bt openreach engineer working on the local street cabinet    about the ping being very hight and Interleaving being turned on  when using the plusnet router      and he said if the speed and i dont have drop outs   then  ping should be lowered by fastpath setting    and Interleaving turned off
but every time i contact plusnet  live chat  it becomes clear  there not got a clue about fastpath
Internet Connection
Showtime
146.199.xxx.xxx
8.8.8.8
8.8.4.4
Line Quality
1116
8828
6.3
6.9
0
0
ADSL2+
19.7
37.5
12.8
0
None
12 days 12 hours 25 minutes 1 second
http://www.speedtest.net/result/5239825513.png
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: ADSL broadband
You have no interleaving, both upstream and downstream have zero interleave depth so you are already on fastpath.
Anotherone
Champion
Fixes: 21
Re: ADSL broadband
@danielmclean
You are on Fastpath, but the ping result you've posted is attrocious, but ping results from speedtesters aren't always reliable. You could try pingtest.net if you want to use a tester, but again it depends on time of day. Does your particular modem/router show errors as well? If so, it should show zero FEC errors on Fastpath.
When running any test to check your connection capability, you must also make sure nothing else is using the connection apart from the test. One of the best tests for ping would be to open a command prompt window and run the command     ping ntp.plus.net
Are you experiencing any problems with your usage of your connection? If so, does it happen at particular times of day?
danielmclean
Re: ADSL broadband
tested with wired connection and wifi off
Microsoft Windows [Version 10.0.10240]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\Users\danie>ping ntp.plus.net
Pinging ntp.plus.net [212.159.13.50] with 32 bytes of data:
Reply from 212.159.13.50: bytes=32 time=1207ms TTL=58
Reply from 212.159.13.50: bytes=32 time=1200ms TTL=58
Reply from 212.159.13.50: bytes=32 time=1225ms TTL=58
Reply from 212.159.13.50: bytes=32 time=1265ms TTL=58
Ping statistics for 212.159.13.50:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1225ms, Maximum = 1265ms, Average = 1224ms
i don't think it shows errors
i have a problems steaming  from bbc and youtube  takes longer than should to start  on every device tested
gaming on xbox one is nearly impossible     and   downloads fail  sometimes fail to start
ping is always above 1000 during the day and sometimes drops during the night to 800
Anotherone
Champion
Fixes: 21
Re: ADSL broadband
That is horrible. Do you have a spare modem/router at all? If not, might you be able to borrow one not locked to a provider? What is this one?
Tell us a bit about your installation. Do you have an NTE5a Master socket? Do you have any extension phone sockets - hard wired or plug in, and what is normally plugged in where? Do you use any extension leads between the phone socket and filter or filter and modem/router?
Do all your Microfilters look similar to this?  Do you have a spare microfilter?
danielmclean
Re: ADSL broadband
i am using talktalk HG635
i have always had it plugged in to the test socket   on the NTE5a master socket       no phone boxes  or anthing else plugged in to the phone line    yes i am using microfilters like the 1 shown and i have replaced it 3 days ago and no change to ping
plusnet are sending out there own branded router   but used 1 before and it just made things refuse to steam and time out
Anotherone
Champion
Fixes: 21
Re: ADSL broadband
Do you have/or can you borrow a corded phone that you could check to see if you can hear noise on the line, using 17070 option 2 if need be.
I'm also rather confused. I'm looking at a speedtest result you posted in December 30Mbps down and 12Mbps up. Either this was a dud result or could you be on Fibre?
danielmclean
Re: ADSL broadband
no noise on the line
speedtest was bt whole sale test   on adsl  not fiber must of been a dud test
Anotherone
Champion
Fixes: 21
Re: ADSL broadband
What configuration settings have you got on the HG635? (I don't mean username/password)
danielmclean
Re: ADSL broadband
Anotherone
Champion
Fixes: 21
Re: ADSL broadband
I would wait until daylight hours as you are on a longish ADSL connection, but the only things I can see there that you could try changing, are change the MTU/MSS to 1500/1460 but definitely uncheck the 'Enable DSL SRA'  as SRA is not used.
danielmclean
Re: ADSL broadband
MTU 1492 /  MSS 1452 is the highest it will accept
unticked sra
i have opened a fault ticket   as well
Anotherone
Champion
Fixes: 21
Re: ADSL broadband
Make sure your computer's MTU isn't higher than 1492.
Any improvement with the unticking of SRA? I'm not really expecting much, it was really a long shot.
Try the ping ntp.plus.net again.
